cinema 4d plugin
A.Lopez
hello,
i'm trying to install octane plugin for cinema 4d but when I load cinema 4d i receive this error message,
thanks,
Roy
Capture c4d octane issue.PNG (13.51 KiB) Viewed 2273 times
Have you read and applied the install procedures? Do you have requirements of the plugin?
A.Lopez
Yes, I do.
I've downloaded cinema 4d 25 last release to try it with octane. I've installed it. Because there is no plugins folder inside c4d path, I've created a new plugin folder on my desktop and, after opening c4d , set this folder as the plugin path. I have an octane render subscription with all the plugins included. when I run C4d with the plugin it crashes, without the plugin it works perfectly.
Roy
A.Lopez
_BugReport.txt
(283.04 KiB) Downloaded 146 times
this is the bug report
jayroth2020
Can you please post a screenshot of your Maxon directory, your plugins directory, and your Octane directory?
A.Lopez
Yes, of course.
Now I've tried to move the plugin folder to the exchange plugins folder of C4d. Now it starts but I can't see octane null part.
jayroth2020
You do not have the plugin installed correctly. You need to create a directory called "plugins", without the quote and a lower case "p" in the Maxon directory. You should then place your c4doctane directory in the plugins directory. Your c4doctane directory should look like this:
A.Lopez
I did it but it crash.
jayroth2020
And you did remove the other plugin from the Exchange Plugins directory, correct?
A.Lopez
correct
