Scene Node Deformer preventing render
atoyuser1
Hi, I am using PR14 R25 on a mac and getting weird results when animating a primitive inside of a cloner
When viewing in Octane's live viewer you can see cube animate,
Live viewer
Live viewer
but when rendering it's stuck on the first frame:
Stuck on first frame
I can fix this by disabling Geometry Axis Scene Node Deformer, or by moving the cube out of the cloner. So I assume it's Geometry Axis that's the culprit?:
Any clues why this might be happening?
EDIT: Sorry, C4D file here:
test3.c4d.zip
Test3.c4d
(76.93 KiB) Downloaded 131 times
new c4d scene node system is not supported in c4doctane.
You need to take out the Block from MoGraph cloner, use the Bake as Alembic command, and use it inside the cloner:
ciao,
Beppe
atoyuser1
Thanks Beppe, is there a release notes with this information?
SSmolak
I have scene where scene nodes works but you must use object+node as instance object in cloner.
