Hi all,
recently my new PC only crashes when I run renders on C4d with Octane and standard, knowing that I generally have more crashes on Octane renders than standard.
Crashes are either blue screens with the message: "*Clock watchdog timeout*", or a direct restart.
The rate of crashes is very fluctuating, example on an Octane rendering of 750 frames on c4d in 1920 x 1080 with a rendering time of 5 sec./frame: a crash after 82 frames, then 216, then 265, etc.
It seems to me that the PC "puts itself in safety", like crash related to overheating or other.
Here is my configuration: Omen 30L Desktop with i9 3.5 Ghz and RTX 3090 with Nvidia Studio 511.65 driver. Cinema 4D R18 with Octane Render 2020.2.5
Apart from the times when I launch renderings, I had no crashes, knowing that the PC is constantly running at the moment for an online backup.
So, in order to know if it is a software or hardware problem, I am looking for software to test the PC in the same conditions as renderings on c4d
Do you have any software names for that?
Have you ever encountered similar problems?
For information i was used to the Mac for twenty years, so little resourceful on the PC.
Thank you in advance for your answers,
Crashes on c4d and Octane with new PC with an RTX 3090
sorry to hear it is not solved, we have talked last time about this here:
viewtopic.php?f=30&t=79420&hilit=watchdog
As said, OctaneRender is not the culprit, but the trigger of the issue.
Have you tried to contact the motherboard manufacturer?
Maybe a bios update can fix it
ciao,
Beppe
ciao,
Beppe
- james_conkle
- Contact:
What OS? I’d recommend nvidia studio drivers 472.84
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
Hi to all and thank you for your replys.
I think, and i hope, that i have found the reason of this problem.
I have open another discusion about here where i have post the solution : viewtopic.php?f=30&t=79420
Thanks to all for your help!
Great find, well done!
Thanks for sharing.
ciao,
Beppe
Thanks for sharing.
ciao,
Beppe
