Turn off Anti Aliasing?
muchogrande
Hi, I'm researching using Octane to create pixel art, and so attempting to minimize/turn of AA. I've set filter size to min (.001) and tried each kernel, but I'm still seeing too much AA. Possible? Any tips?
muchogrande
Thank you elsksa!
muchogrande
Just bumping this again. Although this OSL node helps with texture aliasing, I'm still having issues with the alpha channel. With minimum filter size the alpha is still aliased. Any tips on how to remove aliasing there?
have you tried with "Disable partial alpha" checked, in the CameraImager node?
ciao,Beppe
muchogrande
Perfect! Thank you Beppe!
Lutzyy
I work with large Sci-Fi textures and mix them together using the gradient feature.
The issue comes up when stretchiung them so much that the lines on the texture become blurry.
It seems there isn't a way to add user filtering properly to textures as I've been waiting on this since V3...
I'd love to know a solution to be able to transform the texture when using the "mm_ImageTexture.osl" node as it wont let me do the transform.
Is there something missing in the code or could a dev elaborate on if we will ever get user adjustable filtering?
Thanks.
