C4D-OctaneX-Studio-PR14 has been published too, supporting C4D R21, s22, R23, S24, and R25:
viewtopic.php?f=85&t=77493
You can also find the PR14 Studio and Enterprise versions by visiting your personal Downloads area:
https://render.otoy.com/account/download_archive.php
You need to select your purchased version from the Select Software pop up:
ciao,
Beppe
atracksler
Is v 14 silicon compatible?
atracksler wrote:Is v 14 silicon compatible?
OctaneX PR14 works in Rosetta mode with M1 chip only with plugins.
Standalone PR14 is already native, please try with this version here for macOS Monterey:
https://render.otoy.com/downloads/a2/d0 ... ctaneX.dmg
About plugins, we need to wait for the upcoming 2022.1 SDK:
viewtopic.php?f=33&t=78783
ciao,
Beppe
snahbah
bepeg4d wrote:C4D-OctaneX-Studio-PR14 has been published too, supporting C4D R21, s22, R23, S24, and R25:
ciao,
Beppe
Hi Beppe,
The is no Enterprise version of PR14 as your screen shot shows - I only see that there is access to Studio (see screen shot)
Can you help please?
Hi snahbah,
C4D-OctaneX-Enterprise-PR14 is correctly available in the Downloads server:
Maybe you have a special Enterprise MacPro license, in this case, you need to download PR14 from the following link:
https://render.otoy.com/customerdownloa ... c_PR14.zip
ciao,
Beppe
soulnate
Hi!
I just downloaded the updated Blender build for macOS Monterey, and I found an issue with selecting objects in the viewport. The selection happens at an offset from where the mouse cursor is (i.e: I have to go an inch below where the object is on my screen and click there to select it). I tried resetting everything and using a bone stock version of the build, same result. Any idea where that would come from?
le_wib
Hello !
Is it now compatible with a macbook pro from 2017 (as PR13 was not compatible running under monterey)
le_wib wrote:Hello !
It depends from the GPU inside your Mac, if it is an AMD Polaris (400/500 series), or Intel GPU, they are no more supported anymore by Apple Metal driver in macOS 12 Monterey for GPU rendering, so OctaneX PR12/13/14 cannot use them, and you need to go back to macOS 11.6 Big Sur with OctaneX PR11.
ciao,
Beppe
glowstickbaystudios
Hey yall :) I've been a long time user of Octane X and even a reader of this thread, but I haven't really contributed because my permissions weren't available and I didn't feel like taking the time to mention anything to OTOY. But I went ahead and had it fixed recently, so just wanted to share my GPU benchmark on my Mac Pro with you guys.
As a heads up, I run a 2019 28-core Mac Pro with two w6800x DUO GPU's, essentially four w6800x GPU's. And my score is within proper scaling. It's essentially equivalent to a Puget System running two RTX 3090's. The score is :4 seconds. Here's a screenshot.
This machine is simply a monster when it comes to GPU rendering and I have thought on the M1 Ultra if you care to hear them. Let me know if you do, if not, I won't bore you with my opinion on the future of the 2019 Mac Pro as well as the M-Series Mac Pro releasing this winter and beyond.
glowstickbaystudios
And I guess I should add the recommended Octane Benchmark target, in which case the score is :01 second flat. :)
