IPR Color Differences
Houdini Integrated Plugin
james_conkle
Hi-
After reading Elsksa very helpful blog and reading several other posts on this forum I've decided to post this thread since my "Google 'Fu" has run out on this one.
I have my OCIO config (1.0.3) defined in my system Environment Variables that Houdini is picking up in it's color settings. The applications I use to review my renderings are looking at this same OCIO config.
Inside Octane for Houdini I have my ROP setup to "Automatic Intermediate Color Space" and a Color Space of "ACEScg". The OctaneRT OCIO view is set to "ACES" and "sRGB". The look is set to "OCIO Use View Look". I'm saving uncompressed .EXR files of the beauty pass - no AOV, post effects or denoising.
The applications I use to review my renders are also set to OCIO 1.0.3 and interpreting the footage as ACEScg and the view is set to sRGB. I'm using both DJV and Davinci Resolve to view the renders and they match each other but neither match Octane's IPR.
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
juanjgon
Do you know if the old OpenGL IPR or the MPlay IPR (with MPlay configured to use the right OCIO 1.0.3 config) have the same problem?
james_conkle
Just tested this and all options in Houdini (new IPR, old IPR and MPlay) and they all match exactly - so that's good!
I just compared against Houdini, Fusion and DJV. It looks like they all have some discrepancies. So that sounds like it's either something on my end or a limitation of OCIO/ACES which doesn't seem right. I'll do more digging and report here if I find anything.
james_conkle
Elsksa -
Interested in why you recommend not using ACES? What is this "Filmic" you refer to? If you're talking about using Octane's camera imager I prefer to use ACES for many reasons even if I'm getting slight variation across applications.
I'm using OCIO 1.0.3 since it's the latest version supported by all my applications.
Here is where "Automatic intermediate color space" is enabled you can define the color space of the output file: Image
Return to “Houdini”
