Solaris/Octane basic setup
Hydra Solaris
canderled
Hi Guys,
Could someone let me know how to make a basic setup using octane and solaris?? Octane seems to start ok but but when i try to activate it, it just vanish from the menu. Might it be an install issue?? Octane Standealone is working so it shouldn't be a liscense server issue, Maybe a bad install path or me not setting it up correctly for solaris ??? (I had not trouble with the regular houdini plug)
BK
canderled wrote:Hi Guys,
Hi Canderled,
Sorry for the late response.
Are you still having issues running Octane?
- please check the license Activation status from Options>Licensing>License Management from Octane Shelves.
- also, maybe try removing the backward slash after Win64 in the .env.
cheers
Kind Regards
bk3d
canderled
Hi BK
Yes still no luck using it.
Liscence isn't the trouble It's all good.
I tried removing the \ but still not working. I install the regular houdini plug, this one is running fine.
Look solaris plugin is loading correctly but crash only when i try to activate the viewport render, so maybe it could work with a scene properly setuped? Could you provide me one?
That's so bad , I really want to use this solaris/USD workflow.
BK
canderled wrote:Hi BK
Hi canderled,
Strange! Maybe it's because you have two paths for both OctaneSolaris and our main Octane Houdini plugin.
Octane Solaris is already merged with our main plugin so we do not need to reinstall/path the main plugin.
Please remove the Octane Houdini plugin path and try again!
If it does not work then please send an email via our support [email protected] for further investigation?
cheers
Kind Regards
bk3d
Azure_CN
I have the seem problem too! I just installed solaris plugin by json file, I works well in SOP IPR render, but in solaris, I can't activate persp - octane button, if I do that, the button just disapeared. And can't find that again unless restart houdini. Also, octane can't render in solaris viewport and render rop node.
BK
Azure_CN wrote:I have the seem problem too! I just installed solaris plugin by json file, I works well in SOP IPR render, but in solaris, I can't activate persp - octane button, if I do that, the button just disapeared. And can't find that again unless restart houdini. Also, octane can't render in solaris viewport and render rop node.
Hi Azure_CN,
thank you for the post.
Can you please submit a ticket to our [email protected]?
We may need a remote assist on your workstation to investigate the issue!
cheers
Kind Regards
bk3d
interelectronix
It would be really great to have a octane solaris scene by otoy that is perfectly setup to learn.
Return to “Hydra Solaris”
