Is Z-Depth pass included in "Studio" subscription
rhett
I used to have Enterprise subscription and dropped down to Studio. I can't find render passes like Z-Depth. Are they not included in Studio version? or am I just a little blind.
all the Octane versions have the same features, but:
- Studio versions are less expensive, limited to max 2x GPUs, without Net render and Offline mode
- Enterprise versions have no limitations
If you have switched from 2020.2.x to 2021.1.x, now the Z-depth pass is under Render AOVs/Render AOV group node, you need to click on the Add input button, then select the desired AOV in the No Node menu:
ciao,
Beppe
rhett
Legend. I always get disoriented with UI changes.
