Cinema4D version 2021.1.1-R3 (Previous stable) 01.02.2022
Kalua
aoktar wrote:
Kalua wrote:Hi, Aoktar
The plugin is working really great so far.
One wish I have: When I use "Remove unused materials" command, materials used as "intersection" in "Clipping Material" are removed.
Could it be considered as used? One thing less to worry.
Regards,
It needs to be added to the function. Thanks for reminding
Thank you!
Octane User since V1 Beta
thanulee
Hi, I see hair correct in LV and in PV no matter what they are not visible.
Could you pls help me fix this?
@thanulee
try this way
911ljt
Hi, I found a bug that can guarentee 100% crash C4D & octane.
This happens when you accident drop the "comment node" into node editor when node editor is empty, in other words when there is no active material selected.
Thank you!
thanulee
aoktar wrote:@thanulee
try this way
Thanks Ahmet. But isnt it a bug this one? Shouldnt it work in both LV/PV ?
try this way
A kind of bug. But needs to investigate further.
911ljt wrote:Hi, I found a bug that can guarentee 100% crash C4D & octane.
Great thanks!
Mikla
I have tested couple of other old scenes that were created in 2020.2. All of them come with Non color data as default and incorrect Gamma. This is really frustrating because either I have to go through each node and set them to Linear sRGB + Legacy Gamma or replace the plugin every time I need to work on an older project. Can't you add an option in the plugin setup to default everything to Linear sRGB + Legacy Gamma?
Again I'm on c4d R21.
Best.
Mikla wrote:I have tested couple of other old scenes that were created in 2020.2. All of them come with Non color data as default and incorrect Gamma. This is really frustrating because either I have to go through each node and set them to Linear sRGB + Legacy Gamma or replace the plugin every time I need to work on an older project. Can't you add an option in the plugin setup to default everything to Linear sRGB + Legacy Gamma?
Best.
It's default actually. And I don't see the same behavior on my test scenes. Please send me a few example scenes.
Mikla
Best.
Could it be the C4D version? Can you check it with r21 if you have it? I sent a scene to jayroth2020 but can send it to you as well.
Return to “Releases”
