Ray epsilon problem
Moderator: BK
- LittleFisky
IDK if this is a bug, or feature, but I can't fix in place the "Ray Epsilon" parameter. I set it to 0.000001, then clicking on Studio's viewport - and it goes back to default setting. Any ways to fix it's value?
Have you unchecked "Automatic calculation of kernel ray epsilon" under the General Setting in the preference tab?LittleFisky wrote:IDK if this is a bug, or feature, but I can't fix in place the "Ray Epsilon" parameter. I set it to 0.000001, then clicking on Studio's viewport - and it goes back to default setting. Any ways to fix it's value?
- LittleFisky
Banti wrote:Have you unchecked "Automatic calculation of kernel ray epsilon" under the General Setting in the preference tab?LittleFisky wrote:IDK if this is a bug, or feature, but I can't fix in place the "Ray Epsilon" parameter. I set it to 0.000001, then clicking on Studio's viewport - and it goes back to default setting. Any ways to fix it's value?
It was that simple?? Thank you! Problem solved
