Cinema4D version 2021.1-(R7) (Obsolete) 17.12.2021
moebius wrote:EXR(Octane) does not save? there is no picture in the renderoutputfolder. There is a Picture if i save out TIFF.
Try with English characters
moebius
gosh.
gosh!!!
THANKS.
LFedit
Cryptomatte Object Node Name seems to have some weird behavior. In the past I've use Material Node Name, and Object Node Name for the ability to select just about anything I would need in my scenes. I've set up a simple scene to show what's weird. The Object Node Name is only separating into two layers, LayerID1 and anything other than LayerID1.
Am I missing something that's changed, or is it possible this is a bug?
simpleCryptomatte_test.zip
(92.31 KiB) Downloaded 293 times
Win 10, Threadripper Pro, Dual 3090s
LFedit wrote:Cryptomatte Object Node Name seems to have some weird behavior. In the past I've use Material Node Name, and Object Node Name for the ability to select just about anything I would need in my scenes. I've set up a simple scene to show what's weird. The Object Node Name is only separating into two layers, LayerID1 and anything other than LayerID1.
The attachment simpleCryptomatte_test.zip is no longer available
LFedit
Great thank you!
is there a way to use the Object ID layer as a matte source for Cryptomatte?
moebius
use Crypto Layer "Instance" for each Object?
LFedit
awesome thank you. This all works perfectly.
thanulee
Hi I think I found a bug or this setup is breaking.
See video issue here: https://www.dropbox.com/s/yl3iwy4g56422 ... .webm?dl=0
The black stones shouldnt be black. I also tried with instance node and add the cloner as particle, but still its black.
Scene file: https://www.dropbox.com/s/dfr2r37yo7v23 ... e.c4d?dl=0
Cheers!
nycjunglist
Hey aoktar,
It seems that the only way to add a Diffuse/Specular Toon Ramp is from the buttons in the Toon tab for a Toon material. If you try to connect the nodes manually, they won't connect.
(Animated GIF attached)
Ryzen 9 5950x | 128 GB RAM | 5090 + 3080Ti
FelipeCortes
in 2021.1 R3,cryptomate ignore "invert option" in render layer
Return to “Releases”
