Random OSL Displace Map
kcpr-raffaEl
Hi All!!
I've got question - if is possible to randomize Displace using OSL Texture?
paride4331
Hi kcpr-raffaEl,
You can do it using the Chaos texture node.
kcpr-raffaEl
Thank You for your answer!
I should be more precise:
I need every instance of object to have different displacement, but based on one texture, which position coordinates and rotation are randomized by OSL Script.
I'm not sure if it's even possible... :?:
jobigoud
Per-instance displacement is not supported.
kcpr-raffaEl
Thank You,
That makes everything clear.
Return to “Autodesk 3Ds Max”
