Hi
I'm trying to build custom normal maps. I got most of the steps down, but I'm noticing that the Geometric Normal pass seems to be displaying "neutral" blue as R:87, G:82, B:240 (#5752FO). From what I've been reading, neutral blue in a normal map should be R:128, G:128, B:255.
I've tried setting up a parallel camera to make sure this isn't a result of distortion or something like that - same result.
Is this a bug, or is there something I'm doing wrong, or does it not matter if the color is 128/128/255?
EDIT: Looks like it's the same in Octane Standalone, which I always forget to check - I'll ask in that forum as well, but keep this here in case anyone has any ideas.
Win 10 Pro/C4D S24.111/Octane 2021.1/NVIDIA studio driver 471.68/GTX 1660Ti
Normal map "neutral" color
The Geometric normal pass gives normals in world space. For a normal map you probably need the normals in camera space, but Octane doesn't directly support that.
In 2021 you can create a global texture AOV with an OSL texture that outputs the normals:
At the moment the global texture AOVs are always interpreted as color but the normal map is non-color data. If you want to save it to PNG directly you need an extra step:
- You will need to use the new Render AOV group
- create a Global texture AOV
- create an OSL texture for the Texture input and enter this shader:
shader OslTexture( output vector c = 0) { c = transform("world", "camera", vector(N)) * 0.5 + 0.5; }
- In the AOV output group add a new AOV output.
- Disable imager and postprocessing in the output settings.
- Go to the settings under Layer 1, and then to Input, and change the combo box with the render pass to the global texture AOV created above
Thank you @roeland!
Camera-space vs. World Space was the missing component in my thinking. When I zeroed out the camera and put the background plane straight up and down along Y, I got the neutral color I was expecting.
I'll give the OSL texture a shot next to see how that differs. Thanks again!
This is great - I had no idea this node existed because it's not in the list on the left in the node editor, and doesn't seem to show in any dropdowns in the C4D interface.jobigoud wrote:Instead of the custom OSL it should also work with the new Normal texture node, settingCoordinate spacetoCameraand checkingNormalize result.
-s
