OctaneRender 2021.1 LightWave EOL Tribute build
smount1
Thank you Juan for everything you have done for Lightwave and its community. Best of luck with the next chapter of your life; whatever it is, I'm sure you will do an amazing job. 8-)
pixelsmack
I see Otoy has not released a 2021 network node. I assume I should hold off upgraded to EOL build? Otherwise I'd lose my network GPU capablities?
UPDATE. They have sorry. Found here: https://render.otoy.com/customerdownloa ... de_win.exe
juanjgon
pixelsmack wrote:I see Otoy has not released a 2021 network node. I assume I should hold off upgraded to EOL build? Otherwise I'd lose my network GPU capablities?
The network node download links are available in the Standalone release topic, as usual:
viewtopic.php?f=24&t=78621
dough-cgi
Anything new about the AI Light Problem, I encountered? (my post from Monday)
Godstrike
Thanks Juan!
Ryzen 5800x at 4.4GHz | 32GB | 1 x 3090 ti | 1 x RTX 2080 ti
promity
I confirm - when using the emitter material on massive of instances - Octane and Lightwave are frozen immediately.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
Carlos3D
Thanks Juanjo
juanjgon
dough-cgi wrote:Anything new about the AI Light Problem, I encountered? (my post from Monday)
Could it be a drivers or system issue. Here it seems work fine even with 30x30x30 instances. What GPUs and NVIDIA drivers do you have?
promity
In my scene there are 300 lights (instances) that have hidden geometry responsible for emitting light. But also in each lamp there is a whole cloud (about 3000) of small balls, which should also glow (in fact, not, but the client wanted them to be brighter, so I had to use fake emitters - without casting shadows and light - on these balls - again, now this is not relevant for me, I found a way to solve this issue through the post-process). In the previous version of Octane, I did it without problems. But in version 2021, the LW freezes almost instantly.
Lightwave 3d
Lewis
promity wrote:In my scene there are 300 lights (instances) that have hidden geometry responsible for emitting light. But also in each lamp there is a whole cloud (about 3000) of small balls, which should also glow (in fact, not, but the client wanted them to be brighter, so I had to use fake emitters - without casting shadows and light - on these balls - again, now this is not relevant for me, I found a way to solve this issue through the post-process). In the previous version of Octane, I did it without problems. But in version 2021, the LW freezes almost instantly.
Can you upload that scene and maybe try in ORBX to see does Octane standalonr also freezees ?
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
Return to “Releases”
