Hello
I have a scene setup of a set in Modo with Octane and everything is fine, but than when I
import an object (also prepared with octnae material in another scene) and i
renderit everything is fine, but I cannot edit the material of the imported object...
Even if I try the edit in the node editor option it fails...
I need to do some corrections on the material and I want to do them in the final scene as otherwise
i cannot fine tune the materials...
Any suggestions?
SOME MATERIALS DON'T OPEN IN THE NODE EDITOR
Is this a standard behaviour...
again..
I uploaded a model in this set and its impossible to edit the Octane materials...
All the material below the red line cannot be edited..despite they are rendered correctly...
This is a big issue for me...
I'v found a workaround..to add a new Octane override, in this way I can edit materials but is
a bit stupid to have to do this on imported item...
- Hesekiel2517
Try importing the Modells with the import dialog. For some reason dragging and dropping from another scene does not work
I will try this way.
