Cinema4D version 2020.2.5-R3 (Obsolete stable) 16.09.2021
I've updated the links to provide R25 builds. Enjoy it!
BCres
Thank you, Ahmet. On a quick install and test in R25, it works extremely fast. You're amazing!
BCres wrote:Thank you, Ahmet. On a quick install and test in R25, it works extremely fast. You're amazing!
No problem! Btw R25 builds will require a CPU with AVX2 extension, it may make some difference on speed but breaks the support for old CPUs.
SSmolak
Thank you, Octane works great with the new scene nodes via "Capsules" even with Octane Materials by node selection tags !
davidyannick_1
Just a remark with c4d r25 dark theme Octane LV icons are almost not visible
Kalua
davidyannick_1 wrote:Just a remark with c4d r25 dark theme Octane LV icons are almost not visible
So far the integration is really nice. But I agree: the octane icons are very dimmed in the R25 version.
Regards,
C4D 2025.1.1 Octane 2025.2.1 v1.5.1, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 552.22
Regards,
Dimmed because colors are much darker, and icons has been designed for previous C4D's schema. Now added new set just for R25 and updating the R3 builds again. Re-download and install please a few minutes later.
Kalua
Regards,
Thank you!
davidyannick_1
Regards,
thank you :)
davidyannick_1
But just after installing it I can't see any difference ?
no dif
no dif
Return to “Releases”
