Cinema4D version 2020.2.5-R3 (Obsolete stable) 16.09.2021
twik25 wrote:Hi Ahmet,
I'm running into a situation with the Inheritance tag using octane scatter. With the tag activated, as soon as I move my mouse over anywhere other than the LV, Octane goes into an instant refresh cycle. As soon as I turn off the tag, it doesn't do the refresh loop. I know this issue goes back to 2000.2.3 (I had that running but I installed this latest one and it was still an issue). Any ideas?
Tim
Could you post your scene? I cannot estimate every parameters of your setup. I'm not much expectant to solve this issue because looks like a behavior come from C4D's update system.
anklove wrote:Dirt include objects option doesnt work in this build
I'll fix it for R2 build, thanks for tip!
twik25
Sure. Scene attached!
aoktar wrote: Could you post your scene? I cannot estimate every parameters of your setup. I'm not much expectant to solve this issue because looks like a behavior come from C4D's update system.
Chairs.zip
(108.69 KiB) Downloaded 251 times
twik25 wrote:Sure. Scene attached!
I cannot reproduce the problem with your scene. It's refreshing on every click but not on mouse movements. Here the problem comes from Inheritance effect because it's generating update effects on every user interaction. There's not any safer way to detect the fake update messages.
Kalua
Thanks for the build, Aoktar! It works really well!
I am having issues, though, with the C4D take system: I don't think it is specifically related to the last Octane build: Sometimes changing one simple parameter from any element makes C4D crash - e.g. changing emissor's power.
I noticed having lots of takes make the file + Octane more unstable (over 10 crashes per day). Did anyone else notice related Take issues?
Regards,
Starting Liveview will sometimes make C4D crash or imediatelly close
Simple parameters change will cause C4D crash
Octane User since V1 Beta
SSmolak
Stupid question but important in specific workflow where only node editor and Octane window are opened - is there any way, shortcut to frame selected object in Octane Live Viewer ? Standard shortcuts doesn't work here.
ahh I forgot that I had changed frame objects behavior to "Alt+O" from "O" and Octane support those without "alt" :)
hazenkind
No Octane Plugin in MY S24.037. Any ideas whats wrong?
Please try to repaire the Microsoft Visual Studio (Visual C++) 2015/2017/2019 installation, in general solves the issue.
https://aka.ms/vs/16/release/vc_redist.x64.exe
ciao Beppe
hazenkind
Thx for your quick feedback Bepe. But this won´t fix the problem. Still not found
BCres
hazenkind,
May not be related...but have you tried updating to S24.111? Maybe the C4D v.24 program install is missing something on your system?
C4D S24 updated.jpg (6.16 KiB) Viewed 3863 times
BC
Return to “Releases”
