Cinema4D version 2020.2.4-R2 (Obsolete stable) 20.06.2021
thanulee
PV doesnt render instance node with image. LV is correct.
Scene file: https://www.dropbox.com/sh/i9jk3ws6eypk ... 0DkBa?dl=0
Thanks a lot
eyeonestudio
It would be nice to add a "Step" or "Speed" ​parameter to the Octane Volume Object(VDB Loader).
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
thanulee wrote:Hi,
Thanks a lot
There is an issue in reading the Gamma value.
Try to set it to 0.99, then back to 1:
ciao Beppe
dinf
Hi there,
embedded help (buttons with lights, tags and so on) is leading to 404 error on my computers. Downloadable help is v4.01 only :(
Help in Settings Window Menu will open the new Help window (with a script error, but working).
Is there any chance that I get the interactive help back to work?
Thx!
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
thanulee
bepeg4d wrote:
thanulee wrote:Hi,
Thanks a lot
ciao Beppe
PV renders black, I didnt noticed the gamma issue
thanulee
But I have a very pressing matter which I communicated twice in the past without solving it. This happens almost in all of the scenes I tried render as sequences. They are all complex type of scenes with particles or scatters or alembics etc so its really hard to do tests and see why and what.
PV is simply freezing (and c4d doesnt crash) while network rendering. It stops working on a random frame each time but c4d is responsive. Doesnt crash i can just cancel manually the render and resend it.
- I did format my slave machines, vram is never above 3gb in all gpus. Using win 2009/ 471.41 drivers/ r23.
I am using splashtop (but first time so this might not be related as this issue was present in the past) and noticed that it also drops randomly on one machine sometimes. Maybe this relates to my issue here? Maybe something in network configurations?
thanulee
So after formatting, tried this scene both r23 and s24 and its freezing when slaves join on frame 1:
https://www.dropbox.com/s/aa42515dhn6o0 ... r.c4d?dl=0
This is an old scene I exchange with Beppe 2 months ago. Today had this issue again on another scene, and it seems that there is something wrong here on my setup in network. I d appreciate some remote help.
edit: uploaded the specific slave error.
please make sure to install Standalone in both Workstation and Render-Node, to correctly setup the TdrDelay registry in Win 10.
Your scene works perfectly in Net render here, wiith both RTX ON, and OFF:
Net render RTX OFF
Net render RTX OFF
Net Render RTX ON
Net Render RTX ON
ciao Beppe
iDani
the Octane Light as a disc has a wrong direction (- Z). Rectangle Light is right (+ Z)
cheers Dani
911ljt
iDani wrote:Hi,
cheers Dani
The attachment Screenshot 2021-07-28 082933.jpg is no longer available
Yes Finally someone point this out! I wasnt be able to post in the forum before I was deperately wishing someone will find this problem and report to developer since the latest stable build lol. After long weeks finally!
Here is more screenshot of Wrong direction of OctaneLight.
Wrong Z direction Light
Thx
Thank you!
Return to “Releases”
