OctaneRender™ 2021.1 XB3
Daniel_Ward
Hey Funk,
I hope the Otoy Team give you a complimentary Octane subscription for the outstanding amount of bug reporting you do!
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
abstrax
funk wrote:BUG: Batch render job node doesnt save denoised beauty pass
I'm just trying the "batch render job" node and can't seem to save out a denoised beauty pass (its saving the noisy beauty pass instead).
The batch rendering script works though.
Thanks for the report. It will be fixed in the next release.
TBFX
BUG: It appears the light pass IDs are broken. If I set up a scene with several lights, each with it's own light pass ID and set up light AOV's then only the sun and environment are in their correct AOV's. All the other lights show up in the lightPass1 AOV and any other lightPass AOV's are empty.
I've attached a simple scene to illustrate.
Cheers
T.
LightAOVsBroken.orbx
(76.91 KiB) Downloaded 270 times
Win10 x64|i7-9750H 2.6 GHz|32 GB RAM | RTX2080 max Q 8GB
funk
Thanks abstrax. I think I actually got it working in a second test, so I'm not entirely sure whats going on.
I should have saved the first test and attached it, but it looks like you guys have found the issue anyway.
funk
TBFX wrote:BUG: It appears the light pass IDs are broken. If I set up a scene with several lights, each with it's own light pass ID and set up light AOV's then only the sun and environment are in their correct AOV's. All the other lights show up in the lightPass1 AOV and any other lightPass AOV's are empty.
I had a look at this orbx and all your lights are set to Light pass ID 1 (its in light > material > emission > light pass ID).
I looks like you mistakenly used the object layer > light pass mask instead. This is used to prevent specific light IDs from lighting up an object.
TBFX
Ah, Thanks! Octane and I have sadly been separated for some time and only very recently reunited. I hadn't even considered the light linking feature as it's not something I generally do and assumed that was where to set this :oops:
funk
BUG: Chaos texture histogram invariant blending changes color of texture
1. Load the scene
2. Right click the chaos texture > render
3. Toggle histogram invariant blending on and off
RESULT: When "histogram invariant blending" is enabled, the color is a lot lighter, which is incorrect
chaos_histogram_bug.orbx
(1.28 MiB) Downloaded 367 times
arno
funk wrote:BUG / Limitation? Anisotropy artifacts on triangles generated by Octane's subdivision
I noticed that the new anisotropy generates shading artifacts when I use Octane's (mesh node) subdivision
Thank you for the report. It took a while to track down, but I have a fix for it now that will be in the next release.
funk
Thanks arno
funk
BUG: Hair material producing incorrect melanin colors with new color pipeline
Martimoo brought this up on discord.
1. Load the scene and render
2. Toggle kernel > "use old color pipeline" on and off to see the difference
With the old color pipeline, melanin becomes black at values close to 1. This is correct.
When the new color pipeline is used, melanin at 1.0 becomes yellow, which is incorrect
2021_hair_mat_color_pipeline_difference.orbx
(63.73 KiB) Downloaded 289 times
