Problems with instances
promity
Unfortunately, Octane often crashes if there are a large number of instances in the scene.
I have an insane amount of lamps in my restaurant scene, each of which has about 30 thousand polygons.
In total, these lights would weigh about a hundred million polygons, so I made them instances.
But with my attempts to add other objects through the instances, the LW crashes almost instantly when
starting the Octane render.
However, if I add these objects "physically", i.e. as pure geometry - Octane works well. But the scene gets really hard.
Maybe this problem is on the side of the LW?
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
juanjgon
I'm not sure, to be honest. Can you please enable the Octane log file to check if there is some kind of CUDA error before the crash? If you can reproduce this problem in a simple scene I could take a look at it here.
promity
Unfortunately, the option to save the log file was disabled.
But I have known this situation for a long time - when Octane works better with large arrays of pure geometry, and with instances, the role of which is to relieve the scene from being overloaded with a large number of polygons, it is worse, or rather much less stable.
Lightwave 3d
pixym
Hi, have you tried to simplify your 30000 polygons "lights" ?
To be honest so much polygons for a single light seems overkill for me.
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
promity
This is a very complex lamp, with a hell of a lot of gold droplets inside. I converted these droplets into polygonal points and in the Layout through the plug-in assigned to these points the render as spheres. So I reduced the number of polygons several times, but the light is still quite heavy.
https://3ddd.ru/3dmodels/show/drop_shap ... amp_fial_b
Lightwave 3d
Return to “Lightwave 3D”
