OctaneRender™ 2021.1 XB1
Kalua
Thanks! Good to know.
I think is C4D which is setting 100 as default - or perhaps pre-2020 shaders are set to 100 when reloaded.
Regards,
Octane User since V1 Beta
mojave
funk wrote:BUG: RTX On renders this wrong (EDIT: on a 3090)
The last scene I was working on in 2020.2.3 looks completely wrong in 2021.1 XB1, and Im not really using any advanced features. I've started reducing the scene and have found at least 1 issue with RTX on, rendering incorrectly.
This issue will be fixed in the next release. Thank you for your help.
funk
Great news. Thanks Mojave
funk
BUG: Compositor color correction ignores "enable imager/post" when disabled on render AOV
I have a render AOV plugged into a color correction. If I disabled the "enable imager" or "enable post processing" checkboxes on the render AOV, nothing changes.
aov_color_correction_ignores_imager_post_disabled.ocs
(44.64 KiB) Downloaded 255 times
funk
BUG: Compositor color correction INVERT does nothing
Just use the previous post's OCS and try to use INVERT on the color correction node. It does nothing
funk
BUG: OSL error in this example
I was just doing some random stuff in the new release and this node setup gives me an OSL error
Render the scene and look at the log viewer:
<nodes>:38: error: indexing into non-array or non-component type
We generated invalid OSL code
Failed to compile OSL shader.
osl_error_001.ocs
(46.15 KiB) Downloaded 270 times
funk
BUG: Anisotropy still looks faceted (no change from 2020.2.3)
Im trying to test anisotropy to match the smooth results from the first post, but I'm seeing no change from 2020.2.3
Is there something I'm missing or is this broken in this release?
EDIT: It seems to be because the modo plugin exports geometry with unwelded vertices. I can force "merge unwelded vertices" in the plugin per mesh, but I'm wondering if this could be made to work with the current unwelded geo?
aniso_test_001.orbx
(4.16 MiB) Downloaded 268 times
funk
BUG: Toon material using camera light has blue tint when using d65 white light spectrum
1. If you render this scene, the toon material has a blue tint (which is incorrect)
2. If you set kernel > white light spectrum to legacy, it fixes it
toon_d65_color_tint.ocs
(43.37 KiB) Downloaded 286 times
karl
funk wrote:BUG: Compositor color correction INVERT does nothing
funk wrote:BUG: Toon material using camera light has blue tint when using d65 white light spectrum
Thanks for the reports - these two issues will be fixed in the next build.
vijay
funk wrote:BUG: Compositor color correction ignores "enable imager/post" when disabled on render AOV
These enable imager/post settings are only used from a top-level node ((i.e.) when connected directly to the AOV output group node) and ignored from any intermediate nodes in the chain. The scene you provided has color correction as a top-level node, which doesn't have those settings. Initially, these settings were intended only on composite AOV nodes, But we extended them to Image AOV output and Render AOV output nodes for debug purposes. If you want to use these settings on any other nodes then you need to connect the node to the composite AOV node and use the composite AOV as a top-level node. Sorry for the confusion and inconvenience, we will revisit this in some future build.
Vijay
