P106-100 benchmark score
spartan00j
Hello, I'm having an issue with the p106-100 GPU. The benchmark scores I'm getting are around 50 to 55. On a Form benchmark info area. It says that I'm supposed to get at least a minimum of 70. What can interfere with my tests?
My CPU is a Threadripper 1920x
I have eight 16GB modules
And my motherboard is an ASRock phantom gaming 6 x399.
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
what about the Temperature?
Please, download and run GPU-Z:
https://www.techpowerup.com/gpuz/
And check the Sensors tab, about GPU Load, Temperature and TDP, while rendering in Octanebench.
ciao Beppe
spartan00j
bepeg4d wrote:Hi,
ciao Beppe
Here are screenshots.
I have 2 P106-100 and 1 1650 Super. 1 of the P106-100 is on a x1 Pcie Riser.
Win 11
128GB RAM
RTX 3060 TI
spartan00j
bepeg4d wrote:Hi,
ciao Beppe
Also, are there any known bios setting that I need to change that may cause an issue with Octane.
Win 11
128GB RAM
RTX 3060 TI
everything seems ok, but GPU-Z screenshots are not complete.
Temperature seems ok, but Tdr Power Consumption parameter is not visible.
Please also share a screenshot form GPU-Z Graphics Card tab, thanks.
ciao Beppe
spartan00j
bepeg4d wrote:Hi,
ciao Beppe
sorry. I didn't notice that.
Win 11
128GB RAM
RTX 3060 TI
Ok, thanks for the collaboration.
I think that everything is ok, to be sure, please run OctaneBench 4.00c, and share the result:
https://render.otoy.com/downloads/a/787 ... 0c_win.zip
Unfortunately we don’t have other results in OctaneBench 2020.2.3 for Nvidia P106-090 :roll:
The only similar result is from a different GPU, Nvidia P106-100 in OctaneBench v4.00c:
https://render.otoy.com/octanebench/res ... owRTXOff=0
But Nvidia P106-100 is this:
https://www.techpowerup.com/gpu-specs/p106-100.c2980
While Nvidia P106-090 is this:
https://www.techpowerup.com/gpu-specs/z ... -090.b4832
ciao Beppe
spartan00j
bepeg4d wrote:Ok, thanks for the collaboration.
ciao Beppe
Okay, So I was getting confused by the model of GPU.
Here's the screenshot of using Version 4 Benchtest.
Win 11
128GB RAM
RTX 3060 TI
Yes, as you can see the result from v4.00c is similar.
Please run again the test with 2020.2.3 OctaneBench, and press the Upload button at the end, it will be useful for other users in future.
Happy GPU rendering,
ciao Beppe
