Cinema4D version 2020.2.3-R7 (Previous stable) 09.06.2021
thanulee
MG color shader doesnt work with multi instances. Only with render instances. Tell me if u can replicate. Thanks
thanulee wrote:Hi,
Instance color is solution
thanulee
Ah thanks a lot! Didnt know this workaround!
miohn
I cannot get the Rendernodes 2020.2.3 to work with newest version C4D 2020.2.3 R3.
I'm installing Daemon as always, I set up defender rules as always. But my 2 Nodes wont appear whatever I try.
Is there an incompatibility known with new 2020.2.3 R3?
thanks
Mike
Hi Mike,
Net render is working perfectly here in 2020.2.3-R3, and we don’t have other reports about issues with Net render in 2020.2.3 SDK.
Try to check network port, firewall and defender settings.
If not enough, please write to help at otoy.com, and we will try to investigate more deeply.
ciao Beppe
miohn
Hi Beppe,m
thanks! God to know that it should work with 2020.2.3.
So I have to investigate further on my system.
o.k. it works now!
Somehow the Firewall rules haven't been accepted.
Only after deactivating the firewall completely it worked!
regards
Mike
Anim8me2
I'm having a lot of freezes and I can't seem to pinpoint the issue. Multiple scenes and usually when I am hitting the restart render button. C4D will lock up and I have to force quit it.
Cinema 4D S24
Latest Nvidia Studio drivers
RTX 3090
128GB Ram
Anim8me2 wrote:I'm having a lot of freezes and I can't seem to pinpoint the issue. Multiple scenes and usually when I am hitting the restart render button. C4D will lock up and I have to force quit it.
Cinema 4D S24
RTX 3090
128GB Ram
Disable multi-threading for materials, and please give a feedback
AaronWestwood
Cinema 4D S24
RTX 3090
128GB Ram
Im getting the same issue (with multithreading disabled). Render will stop responding. I cancel it, refresh, but the render doesn't start up in a endless 'loop' with force quitting being the only option. Upon force quitting the Octane/C4D autosave bug report dialogue appears.
As the OP said its hard to pinpoint as it's seemingly random, but quite frequent.
After the render locks up, the C4D viewport still responds to updates just fine, but the Octane LV displays the green text 'updating' but it never refreshes and just spools....
Any ideas?
4 x 2080ti
64gb Ram
Latest Studio Drivers
3D Environment Artist
http://www.artstation.com/aaronwestwood
2 x 4090 // 13900KS // 96GB 5600mHz DDR5 // Windows 11
rwalker
I cannot get C4D R20 to launch past "Initializing Plugins" with this release. I have followed the instructions exactly. New "c4doctane" folder containing "Libs300", "res", and "c4dOctane-R20.xdl64" is in C > Program Files > MAXON > Cinema4D R20 > plugins. I have searched the forum for a fix but I am not finding any help so far.
Return to “Releases”
