Cinema4D version 2020.2.3-R7 (Previous stable) 09.06.2021
BCres
Yes, thank you, Ahmet. The S24 plug is working beautifully. I have tested it all the way out to OCIO rendering into After Effects and it works perfectly! Performance is great.
Off topic, S24 seems a lot more stable than early releases of other C4D versions.
stevenemersonuk wrote:Thank you aoktar! Greatly appreciated :) :D
BCres wrote:Yes, thank you, Ahmet. The S24 plug is working beautifully. I have tested it all the way out to OCIO rendering into After Effects and it works perfectly! Performance is great.
Looks good to me also, adding some more support. Like images from asset browser and C4D materials. Paused to implement 2021 for a few days until it's done!
dynaraton
Thanks for the S24 update! So far, so good!
Asus Prime Deluxe II : Intel i9-10900 X : 128GB G.Skill 3600 MHz DDR4 RAM : (1) Nvidia RTX Pro 4500 Blackwell, (1) Nvidia RTX TITAN: Win11 Pro : Latest Cinema4D
erbe
Hello all,
I install the new release but there is no Network Render option in the settings.
Regards,
Jochen
erbe wrote:Hello all,
Regards,
Jochen
Hi Jochen,
probably you have installed the Studio version, instead of the Enterprise version.
Please, press SHIFT+F10, to show the console, and check to have not the word Studio, near the c4doctane version.
ciao Beppe
Kalua
Hi, Aoktar
Thanks for the plugin update. So far it works great.
Question: what could make my Picture Viewer render all black while Live Viewer renders with no issues?
Regards,
Octane User since V1 Beta
Kalua
I got another question: does the Dirt node Bias parameter work? How well have you guys used it in your projects.
I don't seem to make it work correctly.
Regards,
jayroth2020
You can review the documentation on dirt here: https://docs.otoy.com/cinema4d/Dirt.html This aspect of dirt can be very subtle.
feels
Great release, thanks.
I'm encountering issues of the live viewer not updating when I change parameters in the node editor - my node editor is docked as a tab in the UI. Sometimes I also have to click on the material in the Material Manager a few times in order for the nodes to show up in the node editor. Running the latest C4D R23 build.
Everything else runs very stable and fast. Thank you!
Hi feels,
in Live View, there are four new icons to better manage the Live View update, for Geometry, Lights, Cameras, and Materials.
Please make sure that Material update icon is dark active:
ciao Beppe
Return to “Releases”
