Cinema4D version 2020.2.3-R7 (Previous stable) 09.06.2021
divasoft
aoktar wrote:
Viki.SK wrote:Its not relevant but is there any plan to make a Simplified UI like Redshift's recent testing?
This=> https://www.redshift3d.com/forums/viewthread/36701/
Our system is far simpler for my opinions. I cannot see that, what kind of simplification that's better?
I agree with you. Octane render setup is pretty good.
Viki.SK
I thought that having all the settings inside cinema4d render settings will be simpler rather than having them at different places (OCIO for example). Maybe its just me :)
Have a great day!
Viki.SK wrote: I thought that having all the settings inside cinema4d render settings will be simpler rather than having them at different places (OCIO for example). Maybe its just me :)
Have a great day!
OCIO and a few parts may looks confusing. Most of settings are in render settings too, we cannot change settings window. It's highly integrated. But you can copy all settings to renderer part. Also OCIO has to be in two places because of design requirements. Display and outputs parts are different. You cannot use OCIO for imager in render settings. It's for output.
Secretwoodsrl
Hello! Thank you for this new build, unfortunately I found a bug that is a bit annoying.
In the Octane Node Editor, if I search something using the box "Search" in the top bar of the window, C4D freezes.
If use spacebar I don't have any problems to search nodes.
Secretwoodsrl wrote:Hello! Thank you for this new build, unfortunately I found a bug that is a bit annoying.
Could you please read my previous post about it?
glimpse
Good day,
Any insight on this: https://www.facebook.com/groups/OctaneR ... 676768435/
dynaraton
Please update for the new S24 when possible... I know it will take some time.
The new features of the place/scatter pens are great.
Asus Prime Deluxe II : Intel i9-10900 X : 128GB G.Skill 3600 MHz DDR4 RAM : (2) Nvidia RTX TITANs w/ NvLink : Win11 Pro : Latest Cinema4D
wrapthereal66
+1 please update for r24 ! all my plugins work exept octane !
Thanks you !
divasoft
Hi Ahmet, do you planning to implement support for transferring particle color to mesh (x-particles)?
It was necessary before, but now that insidium has made the possibility of uv advection it is absolutely necessary.
Moreover, now you have full access to the x-particles api.
xpOpenVDBMesher - UV Advection - Sneak Peek https://youtu.be/x8aQxHLFkoc
thanulee
Hello,
Yes please add xp features if possible as the one mentioned above.
I came to report a bug, thin wall doesnt work in sub materials.
Return to “Releases”
