Hello,
how can I use "W Coordinate" shader in materials. Can I use it similar to vertex map in C4D? May be I can use it to mix textures based on weights of vertexes.
Thanks..
W Coordinate Shader
It's a shader to use with hair. For a gradient to the length of hair by sample.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
If You want to use vertex maps, then probably the newest version will make You happy cause it supports them to some extent
Cheers
Luke
Cheers
Luke
// Behance: https://www.behance.net/LukaszKondek //
- Octane v3
- 1x Geforce 980 Ti , and 1x 570 GTX
- Octane v3
- mikeadamwood
Is that the new as in test release? How does it work?lukas8410 wrote:If You want to use vertex maps, then probably the newest version will make You happy cause it supports them to some extent![]()
Cheers
Luke
Windows 11 Pro | ASUS Pro WSX80E | AMD Threadripper Pro 5975WX 32-Core | 256GB Micron 8x32GB 3200MHz ECC | 2x PNY RTX6000 ADA
What are you doing exactly? It's designed just for hairsCristal wrote:W coordinate works with render hair enable, but it doesn't with instance, even if the object has "octane object tag" on it.
Any tip?
Please someone help here. Or maybe Octane as I don't know if this is possible. We are talking about HAIR COLOUR IN OCTANE
1. If you want to add a gradient to each hair you must use W Coordinate node on Octane shader to work properly, and it works, so you can archive something as the grass photo in this thread.
2. However if we use INSTANCE on HAIR, (use any polygon we had made as a hair), W coordinate doesn't work. And it doesn't work either if we apply the texture on our polygon (the hair instance)
So, if the photo attached is HAIR with a hair instance, how can I give that yellow color on the end of the hair and white on root?
Thank you!!
Thank you!!
How it can be a hair primitive if you use mesh for hair? As said that's just for hairs. Put your object here to get a quick support, I'm not support to spend my time for estimations. Thanks for understanding.
