Then thats messed up because i've followed octanes exact settings for linear. I even followed the After Effects settings otoy has in the manual. And it doesnt work.
Before you say "UPDATE". I cant as i have many open projects and updating right now wouldnt be wise. I am running 2020.1.5 R4. Are you saying that the linear workflow that we've just described doesnt work with that version of octane?
Can you confirm my understanding on Linear Workflow?
- jayroth2020
The settings we discussed here will work for you. Nothing I have commented about invalidates that.
In your case, as I have previously written, I would use EXR(Octane) over PNG, especially for comp work. PNG is a lossy format.
Not lossy but embedded sRGB colorspace, not proper for linear workflow. Always prefer Octane(EXR).jayroth2020 wrote:The settings we discussed here will work for you. Nothing I have commented about invalidates that.
Also just one note: Tonemapping will not work with linear buffers.
- RSgraphics
Hi Oaktar,
If linear buffers dont work with tone mapping, then what am i suppose to choose here...
RS,
If everything is still looking dark in AE, have you checked you footage interpretation (right clicking on the file(s) when you first import? I believe AE converts everything to linear light for 32-bit by default.
And do you use display management? That can affect things, too. What is your output from there?
I've switched over totally to OCIO (ACES-CG), but perhaps if you could upload even one frame (even just a primitive in normal light with your settings.) I could see if I have the same issues importing in AE.
I can only check these forums when I remember, but I'll make a point of doing so for the next couple of days.
BC
BC
