January: Octane License Competition *CLOSED*
A forum which hosts Octane Render Artwork Competitions
Locked
OC-T
thanks radiance,
I used a bend ground plate and mapped (uv) the image on it.
The scene is lit with an low resulution hdri image.
cheers
OC-T
GPU: GeForce 8800M GTS, driver 195.62
CPU: Intel T8100 2.1 GHz
Windows Vista, SP2
pedrojafet
Hi there...
There's another try. A latex cover...
I did it with Lightwave, using cloth dynamics over a car.
The spot efx was made with a circular grayscale mapped in the ground.
Afterall, I used the freeware Hotpixels to remove the fireflies. :D
Comments are welcome.
BR.
Making of Lightwave
Making of Lightwave
Win 7 PRO64 | Geforce GTX2750 - 1.8GB | MB ASUS w/ i5 2500 | 8GB
pixym
I like the concept very much (cloth under the pillars).
Happy to see another LW user here.
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
uniqued
hello I`m puting this because I dont know how to grab from the picure "fireflys" I read that there is a software that do it automaticly.
Or maybe I`m doing something wrong that tey apear that much?
What you think?
simple test gforce GTS 250 - 17 min rendertime
ROUBAL
Funny model, I like it.
I got poor result with denoiser softwares (no effect or on the opposite blurry image).
To reduce fireflies (as they are placed randomly at each render), you can render two times and add the second pass over the first one with 50% transparency (in Photoshop or Gimp for example).
Then you can remove the remaining brighter fireflies with the one pixel clone pencil.
I also noticed that the amount of fireflies depends a lot on the hdr image choosen for the image base lighting.
mlody47
Hey,
Im posting my renders in octane for competition.
All images was rendered with geforce 8800 GTS 512
ring ( all shots ) was rendered in about 7 min each - 40.000 polys
and the bottles ( all shots ) was rendered 3 min each - was deleted after crash sorry :)
resolutions was 1024X512 - default
removed fireflies ( all of them ).
Hope You like it.
If I can submit more till 7th feb then I will
i7 2600K + 2X gtx 580 + GTX 560 Ti + 8gbram + Win7 +
AUTODESK SOFTIMAGE 2012
www.behance.net/mlody47
ROUBAL
New Entries :
2048 samples per pixel - 00:17:21 -1088495 triangles -393.9/511 MB Memory used.
Proof Screen :
2048 samples per pixel - 00:17:12 -1088495 triangles -393.9/511 MB Memory used.
Proof Screen :
Nota : I'm sorry for the images displayed full screen I haven't been able to find out how works the "attachment" system.
I have tried to upload through the attachment feature at the bottom of the page, without success (I use IE7).
Sam
Hey that's much better ROUBAL !
Very nice entry I like it
http://Kuto.ch - Samuel Zeller - Freelance 3D Generalist and Graphic designer from Switzerland
[gk]
ROUBAL :
You should do some better composition.
Right now its a standard "must see all" family-type photo composition.
You should try do a range with dof and off angles to catch the details.
Also play with the post filters and exposure/contrast relations.
The carpet doesnt help I think, it sucks to much light - a carpet does that, but it makes your scene extremly heavy.
You got the scene and the shaders, It just needs to be framed and color corrected better.
Amiga 1000 with 2mb memory card
ROUBAL
@Gk : I'd really want to improve the scene and choose other angles, but as said before, once every material adjusted Octane crashes as soon I move in the view, or as soon I change the ibl map.
Last time it crashed when I switched to Photoshop Elements to paste the screen capture. So I have never been able to get more than one image from a setup, and adjusting all materials again takes at least one hour each time. :cry:
It is like building a house of cards with an air fan on the table ! :roll:
For the "heavy" look of the scene, it is what I wanted. It is not a clear-empty modern appartment. It was the style of years 1920-1930 before Art-deco. In fact, I wanted the carpet to be even darker, but it catched too much light.
Locked
Return to “Competitions”
