Cinema4D version 2020.2.1-R3 (Obsolete stable) 23.03.2021
m2001
aoktar wrote:Again that's interesting nobody gives feedback for performance/stability improvements, just problems. Ok, we assume this is a really good performer. Thanks!
in my view
- more stable
- better response
- a bit faster
i´ve no RTX card.
in my view
- more stable
- better response
- a bit faster
i´ve no RTX card.
Thanks for feedback!
anwasif
Hello aoktar,
Thanks for the update. The spotlight is broken in this release.
Attaching some snaps.
Thanks.
anwasif wrote:Hello aoktar,
Thanks.
It's not about my revisions, seems like default behavior changed from core. Adding a floattexture will fix it as a work-around
Kalua
Hello, Aoktar.
The denoiser blend slider seems to not work in some cases (in this case, R23). Please refer to .gif
Regards,
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
Kalua
In general I feel it really stable, it gets better by every big update. I have only found some smaller issues (the ones I have posted along this topic)
Thanks once again for the development!
Regards,
blackcat321
aoktar wrote:
blackcat321 wrote:I have a problem. If I turn on viewport rendering, I can't record keyframesImage
I can do, please give detailed info! What's OS/C4D versions? And what kind of scene?
c4d R21.207 studio461.72 octane2020.2.1 If I turn on the preview, no object can record keyframe
video.zip
(9.02 MiB) Downloaded 226 times
divasoft
Ahmet, octane is much much more stable when before.
Maybe even better than RS now.
Good job, we appreciate.
zoppo
It's the same in R20. As a workaround you can set a keyframe, double click it in the timeline, and then change the value accordingly.
C4D 2025 | Win10
Not sure what's different but I can do! How do you start render and where's the LV window?
Return to “Releases”
