Cinema4D version 2020.2-R3 (Obsolete stable) 19.02.2021
newartstudios wrote:Another issue is inaccurate F Stop for octane camera. F 0.5 should give You insane shallow depth of field, but it's barely noticeable. This looks more like F 4.6. I can crank up aperture edge setting to max value 3, but it still doesn't match reality.
It's minimum value of Standalone which is accepted
divasoft
Yes. we know, but it incorrect.
hazenkind
newartstudios wrote:F 0.5 should give You insane shallow depth of field, but it's barely noticeable.
Hä? This depends on your focal length and scale of your Szene/ Objects also Sensor Size.
newartstudios
I can make the same scene in real life with real objects with my camera. The distance between objects is like half meter. In real life - those objects will be totally blurred out with Sigma Art 1.8. with 0.5 meter distance from each other. So imagine how it should be with 0.5, but there is no glass in real life to compare. Also I used sensor size and focal length 36mm for octane camera, my camera have super 16 mm with focal length 18mm, with will make no big difference in any case. And ether way if I adjust Octane camera to my cam settings - will not match.
newartstudios
I can make the same scene in real life with real objects with my camera. The distance between objects is like half meter. In real life - those objects will be totally blurred out with Sigma Art 1.8. with 0.5 meter distance from each other. So imagine how it should be with F 0.5, but there is no glass in real life to compare. Also I used sensor size and focal length 36mm for octane camera, my camera have super 16 mm with focal length 18mm, which will make no big difference in any case. And ether way if I adjust Octane camera to my cam settings - F stop will not match. In my example it looks more like F4.6
bellini_490
Is the Denoiser and Denoiser passes supported on this version?
I have a 3090GTX
Window enterprise 2004 rev
Latest Nvidia studio Driver.
Cinema4d R23.
bellini_490 wrote:Hi,
I have a 3090GTX
Cinema4d R23.
Yes
thanulee
Hi I get a crash when I "render to PV"
I think its the tokens (using CV tokens also) path that doesnt find the appropriate folders? Didnt have issues with other versions it just created folders in wrong places that was it.
Take a look please: https://www.dropbox.com/s/yanjrdgzx1wpm ... h.c4d?dl=0
desire
Hello, Aoktar!
What have changed last years with circle and cylinder light sources? I remember ideal smooth shapes and from some point the shapes became polygonal, angular
please, see screenshots
if I'm wrong, I'm sorry, but... can't find where to adjust the smoothness of the shapes. If at all possible.
Thank you
circle shape
circle shape
cylinder shape
cylinder shape
thanulee
Another issue i see is this "new" scene in R23.
The very moment I added render presets with octane, it takes 10-15 sec to save an empty file! And if i set scene as default its 10mb while completely empty.
What am I missing here?
scene file: https://www.dropbox.com/s/1egk9bw8g4rrqw7/new.c4d?dl=0
EDIT: magic bullet looks causes this
Return to “Releases”
