How can I render mattes for materials that use poly selectio
granthoki
I have a model with several materials applied using poly selections. I don't need a matte for the entire model, just two of the materials. Is it possible to kick out mattes this way?
3930k | 32G | Asus Sabertooth x79 | 3 x 980ti
granthoki
Thanks for the reply! I'm a little confused with the technique you linked to. The object tag sees the object as a whole, while I need mattes for different textures assigned with poly selections on the same object.
sorry, my fault, didn’t read too carefully.
In this case, a solution is to create a take with all diffuse materials, and assign a glossy with Index 8 to the poly selection, then use the Material passes like Material Reflection,mor IOR, to obtain the mask:
You can use different IOR settings to obtain more than one gray selection.
ciao Beppe
ceen
did something change here n the last releases? Is it possible to make a multipass mask from poly selections?
RTX 5090, Maxon One
ceen wrote:Hi,
what's up with material masks?
ceen
aoktar wrote:
ceen wrote:Hi,
You mean MatID? BW masks are a bit easier to handle. More clean sometimes.
RTX 5090, Maxon One
for Polygon Selection mask, you can use the CryptoMaterialPinName pass:
ciao Beppe
ceen
bepeg4d wrote:Hi,
ciao Beppe
Awesome. Thx!
RTX 5090, Maxon One
