Cinema4D version 2020.2-R3 (Obsolete stable) 19.02.2021
dynaraton
CCIDgfx wrote:
aoktar wrote:CCIDGFX,
It only happens if you have AI upsampling. Otherwise try with a different scene or send your scene!
AI upsampling is not enabled and this is a different scene.
Here is the scene file
https://www.dropbox.com/s/pk0pjyw4rodmy ... Y.zip?dl=0
That's strange. I downloaded your scene file and it works fine for me. It even works with the Al Upsampling turned on. Maybe some one else can check on their machine?
Asus Prime Deluxe II : Intel i9-10900 X : 128GB G.Skill 3600 MHz DDR4 RAM : (1) Nvidia RTX Pro 4500 Blackwell, (1) Nvidia RTX TITAN: Win11 Pro : Latest Cinema4D
CCIDgfx
Then it's definitely something on my end...I just can't figure out what.
Thanks for taking a look
3D Motion Graphics Designer
Intel i9 13900K / 128gb DDR5 / 1 Nvidia 5090 FE / PSU EVGA 1600w / WIN 11
SSmolak
Excluding Thin Film Layer from material attribute manager still leaves Film index parameter in Node Editor :
@ CCIDgfx: as dynaraton has already said, I can also confirm that your scene works correctly with AB Compare here:
The only thing that comes to my mind is to remove the installed version and download and reinstall again 2020.2-R3 :roll:
ciao Beppe
CCIDgfx
bepeg4d wrote:@ CCIDgfx: as dynaraton has already said, I can also confirm that your scene works correctly with AB Compare here:
ciao Beppe
I Actually did that before I posted this thread =/
feels
Thank you aoktar! I noticed a couple of things with this release:
1) The dirt node doesn't affect bump.
2) The chaos node doesn't behave correctly with normal maps when you try to bring the intensity of the map down using the power slider.
3) The solo function behaves unpredictably; sometimes it works, sometimes it gets stuck in the solo mode and I have to go back to Octane Settings and change my kernel back to Pathtracing.
feels wrote:Thank you aoktar! I noticed a couple of things with this release:
1,2 is not plugin related.
Nr.3 is a plugin implementation. I can help you If you can describe the steps to reproduce it.
Kalua
N.2: I have also reported some weird behavior with "Chaos Node + normal maps" here and Stand alone site: viewtopic.php?f=24&t=76901&start=10
Otoy didn't say anything.
Help me bump this issue if you will.
Octane User since V1 Beta
jayroth2020
Kalua, what value is the phong tag set to? Cinema usually defaults to around 40 or so...
newartstudios
I have the same issue with store render buffer. Render buffer screen is in dark grey color. When I press button 'P' or right click on render buffer screen - and choose color picker - and I move my mouse on grey screen - it shows colors. (bottom picture) Render buffer screen works only when I zoom in or out. (top picture) Doesn't work in any kind of scene, tried different settings, can't figure it out. It worked fine with 2020.1.5. I have latest Nvidia studio driver.
Cinema 4D R20
Return to “Releases”
