ORC ORBX Export using Take System
We are working on a solution for this for RNDR (which is replacing ORC), but it’s likely a few months out.
You can do with a simple script
command for exporting orbx
- a1.jpg (16.46 KiB) Viewed 4508 times
You have to export different orbx for each takes. It's what possible
Exporter will save what you see in LV. It will if you see in LV. C4d hair is for styling, octane mat is for visualise the materialDazhai wrote:Thanks for your reply.
C4D Hair works as well? I rely on the c4d hair mat for the styling, will that get baked into orbx?
In this case we need a script that export every take as .orbx.
Now we have to export takes (there is a tool in cinema4d for that) but we have to open every single c4d file and export them as orbx file. I have 2000 takes currently. I tried to use RNDR rendering but after 2 hours I reached this issue.
is there any script for that?
Edit: I just realized that even if I write a script or found one that can export every takes as separated .orbx files, I can't upload them because 254 MB each... I think we have to wait for use take system with RNDR.
