Node Editor Bugs
v-cube
Hi Paul,
some Problems with the node editor:
Rhino-Node-editor-bugs-2021-02-18.mp4
(4.36 MiB) Downloaded 3339 times
Can you please fix that?
Andreas
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
v-cube wrote:Hi Paul,
Andreas
Hi Andreas, what version of the plugin are you using please?
v-cube
latest test build
Thanks. I have reported these bugs to OTOY previously, and thought they had been fix, but I will report them again. As they are issues in the Octane API, there is no fix I can apply at my end.
v-cube
thank you !
karl
I believe both of these issues are caused by the same thing: child windows appear beneath the node editor (the tooltips are technically "windows" too). This doesn't happen in Octane standalone, and I'm 99% sure it's caused by the way we create the dialog window via the API. I'll investigate the problem a bit more.
v-cube
karu wrote:I believe both of these issues are caused by the same thing: child windows appear beneath the node editor (the tooltips are technically "windows" too). This doesn't happen in Octane standalone, and I'm 99% sure it's caused by the way we create the dialog window via the API. I'll investigate the problem a bit more.
Thank you Karu, it is really appreciated! These things have been there for quite a while I belive, but since I am now diving deeper into the node editing approach they become really important for a fast workflow.
Return to “Rhinoceros 3D”
