Hi all,
I'm having this kinda annoying issue where the live viewer keeps refreshing (3-4 times) before it renders out a frame completely. It also refreshes everytime I click on an object, or select a material...
This only happens if I put a vertex map on (whatever) object en enable the fields. That, and also in combo with x-particles. If I delete the x-particles system AND disable the fields onthe vertex map, the LV goes back to normal behaviour. Is there something I have to keep in mind when I enable fields on a vertex map in Octane? I knew about this issue when using X-particles, but was not aware about the fields..
In attachment a the scene I'm working on where the LV refreshes all the time when the fields are enabled. Try deleting the x-particles system and disable the fields on the vertex map. LV should go back to normal.
I'm using S22.
Kind regards,
John
Vertex map fields live viewer refreshes
- tester2.zip
- (3.44 MiB) Downloaded 163 times
Hey Aoktar,
Thx for answering! I sended the file to e friend who works with cycles, and this issue does not appear with him. Is there really no workaround? It's a bit frustrating to work like that, since I'm using XP and vertex maps with fields a lot for a job right now. If not, so be it. But one can only ask
Thank you in advance!
Kind regards,
J
Kind regards,
J
It does same on RS or C4D's renderers, don't know why Cycles didn't same. Maybe not tested same. But I know this is not an issue or fixable thing. Work-around is to disable "geometry update checks".Labrats wrote:Hey Aoktar,
Kind regards,
J
