Cinema4D version 2020.2-R3 (Obsolete stable) 19.02.2021
thanulee wrote:Hey,
R20 and sss materials issue. When i enable nested dielectrics from the kernel, the material changes a lot.
See images and scene below:
https://www.dropbox.com/sh/mgt2unuh5i54 ... 8tsGa?dl=0
the nested dieletric option should be used when you have a Specular material inside another Specular material, and you should change the Prioriry value in the Common tab as explained here:
viewtopic.php?f=24&t=76901
But in your scene, there is not a Specular inside another Specular, but a Specular on top of another Specular, so the Nested Dielectic option should not be used, isen’t it?
ciao Beppe
thanulee
bepeg4d wrote:
thanulee wrote:Hey,
ciao Beppe
Hey Beppe,
I am not using nested dielectrics are on by default.
On top of that add an icecube with some bubbles in this scene. Then what happens? SSS ruined or icecube works correct?
Could u elaborate on this scenario im describing? Suposedly when everything on same priority this thing shouldnt happen
I dont understand why u change priorities on the materials here. Could u explain? Its already buggy since values over 100 are not used anyways
thanulee
@bepeg4d
Even if i set the priority to 1 on all or some materials, the issue is still there (R20).
the Priority value has been already fixed and will be part of the next 2020.2-R2 update.
About the specific scene, we use thre same settings like in Standalone, and your scene is reacting in the same way also there:
So please, post the .orbx scene in Standalone 2020.2 discussion, thanks:
ciao Beppe
SSmolak
aoktar wrote:
SSmolak wrote:If "Use Octane for OGL Previews" in Settings is turned on changing color doesn't update in viewports. LV OGL Previews is turned ON.
ALSO - is there way to support C4D Layers Solo Mode by Octane ?
Could you please give more info because it's working well
It works only for first time please see : www.atlantis-arts.com/OctOGL.wmv
It works only for first time please see : http://www.atlantis-arts.com/OctOGL.wmv
try with a different layout and let me know the results, also send me your used layout.
SSmolak
But it doesn't work for any layout even for these standard built in.
thanulee
bepeg4d wrote:Hi,
ciao Beppe
So its a bug? Im confused :)
Since it is how the core 2020.2 engine is working, it is something that you cannot control from plugin side.
Nested Dielectric is a new feature, so better to ask to the core devs about usage and behavior.
ciao Beppe
dynaraton
I can Confirm with SSmolak. When I have "USe Octane for OGL Previews" checked - my colors or textures do not update on my objects in the Viewports. Only when it is unchecked , the changed textures and colors are visible in the viewports. It seems to work only one time but if you switch to 3rd texture or color it doesn't work.
Asus Prime Deluxe II : Intel i9-10900 X : 128GB G.Skill 3600 MHz DDR4 RAM : (1) Nvidia RTX Pro 4500 Blackwell, (1) Nvidia RTX TITAN: Win11 Pro : Latest Cinema4D
Return to “Releases”
