Cinema4D version 2020.2-R3 (Obsolete stable) 19.02.2021
CCIDgfx wrote:Hi Aoktar,
Looks like Store Render Buffer isn't working. Nothing shows up on the right when I change anything.
Probably you haven't tried without AI upsampling?
CCIDgfx
AI Upsampling was on but even when I turn it off nothing shows up.
3D Motion Graphics Designer
Intel i9 13900K / 128gb DDR5 / 1 Nvidia 5090 FE / PSU EVGA 1600w / WIN 11
Kalua wrote:Hello, Aoktar
As soon as I create and start tweeking with Toon shader, Octane crashes - please refer to .gif.
This error won't happen within Stand alone.
Regards,
there is an issue in 2020.2 SDK with Toon material.
The issue has been already fixed for the next SDK update.
In the meantime, if you need to use the Toon material, please go back to 2020.2-RC6, thanks.
viewtopic.php?f=85&t=76633
ciao Beppe
Kalua
Regards,
ciao Beppe
Thank you, Beppe!
Octane User since V1 Beta
Kalua
I have a question: Does the "Chaos node" works on all normal maps properly?
In some cases they seem to work just fine while in other cases it produces some weird results. Please refer to .gif
Regards,
thanulee
Is there an option to remove this square from the middle of nodes? I find it inconvenient, as I am used to double click to remove a wire and this gets in the way very often.
See image below. Thanks
thanulee
Also dirt doesnt work with bump. Even via a bake node. It would be useful for many cases to have this option.
SSmolak
If "Use Octane for OGL Previews" in Settings is turned on changing color doesn't update in viewports. LV OGL Previews is turned ON.
ALSO - is there way to support C4D Layers Solo Mode by Octane ?
cannon126
I get a shadow pass in my renders when no shadow pass is selected...no matter what I do. It is also just black, and doesn't actually contain information.
Also, the node editor is unstable. So many crashes during any operation.
Anyone else share these problems?
Ryzen 5950x - 2X RTX 3090 - 128GB RAM
Windows 11
thanulee
Hello,
R20 has a problem with store render buffer and renaming the stored images. See video below
eg. im pretty sure render region has issues, I couldnt reproduce now but already happened to me few times
https://www.dropbox.com/s/jms6voypcevdo ... .webm?dl=0
Return to “Releases”
