OctaneRender 2020.2 for Houdini Production build 2020.2.0.4
juanjgon
This is a production release of the OctaneRender™ 2020.2 for Houdini™ plugin compiled with the Octane 2020.2 core. This 2020.2.0.4 release is available for the latest Houdini 17.5/18.0/18.5 production builds on Windows x64, Linux gcc6.3.1 and MacOS 10.12.
Make sure to use an NVIDIA Studio driver with version at least 456.38 on Windows or 455.23 on Linux to use this version. No driver updates are required for macOS 10.13 (CUDA).
New features
To learn more about the new features and improvements of OctaneRender 2020.2, please check out the 2020.2 release post, but this is a brief list of the main new features that have been added.
  • Improved RTX performance.
  • Fast Spectral Nested Dielectrics.
  • Denoiser support for the new NVIDIA Ampere devices.
  • ACEScg and filmic processing. New color options available in the Octane ROP node.
  • OpenColorIO Management, Display and Export (OCIO profile). Configured from the "OCIO" environment variable.
  • OpenColorIOColor graph nodes. Look, Profile and View nodes
  • Integrated multi-scatter from volumes or surfaces. Available in the Octane OBJ spare parameters.
  • User generated compositor AOV passes for combining render and light passes in full a compositor node graph.
  • Null material.
  • Spotlight texture.
  • New ray type, texture composite and channel tools shader nodes.
  • Improved color correction node.
  • New chaos texture node.
Release 2020.2.0.4 Enterprise subscription license
https://render.otoy.com/customerdownloa ... rprise.zip
Release 2020.2.0.4 Studio subscription license
https://render.otoy.com/customerdownloa ... studio.zip
Standalone 2020.2 version for the network rendering nodes
viewtopic.php?f=24&t=76901
Release Notes
RELEASE 2020.2.0.4
* PLUGIN FEATURES AND FIXES:
- Fixed a rendering crash on Linux related to the OCIO config.
- Fixed a problem with the output image filenames without extension in the path/prefix.
- Fixed a problem with the forced phantom and shadowless objects while rendering sequences in update scene mode.
* OCTANE 2020.2 FINAL FEATURES AND BUGS FIXED:
- Fixed auto bump map output which was incorrect for the geometries (mainly for polygon with more than 4 vertices) in clockwise winding order.
- Fixed denoiser output to be slightly brighter when the render layer is enabled.
- Fixed alpha channel which was incorrect when the raw pass in the render passes and the pre-multiply alpha in the imager settings are enabled.
- Fixed toon material showing artifacts when vertex displacement is used.
- Fixed CUDA failure when the scene contains a material with a vertex attribute texture and emission.
- Fixed null material not triggering an update when its smooth pin and its rounded edges pin changes.
- Fixed missing update of composite texture when input textures changed.
- Fixed emission pass which was mistakenly including volume absorption data along with emission data.
- Fixed brightness of emitters in the denoised result if an environment medium is used.
- Fixed normalized info passes of the render AOV output in compositing.
- Fixed AOV list of the render AOV output node.
- Fixed how instance IDs are computed from grid coordinates in Scatter in volume tool.
- Fixed a crash in the surface scatter node which happened when you choose mode "Relative density" and create a new texture node for the density input.
Happy rendering,
Your OTOY Team
caseyhupke
so far so good! My wild scene that would instant crash on all previous builds is running very smooth.
now with OCIO and Denoiser!
Is there a way to preview luts/colorspaces in the IPR that I'm not seeing, or do we have to render to disc to see the differences?
stevepickup
Awesome!
Just one question, any reason I get this warning, had it for the last few RC versions too.
[OpenColorIO Info]: Color management disabled. (Specify the $OCIO environment variable to enable.)
juanjgon
caseyhupke wrote:Is there a way to preview luts/colorspaces in the IPR that I'm not seeing, or do we have to render to disc to see the differences?
As far as I know, the preview luts/colorspaces/ocio is always handled using the imager camera node in the render target. Now it even has an ocio view and look inputs to attach the oicio nodes and preview the ocio color spaces. In any case, the workflow is the same found in Standalone.
juanjgon
stevepickup wrote:Awesome!
This comes from the Octane core, I think, probably due to the lack of the OCIO environment variable pointing to a valid ocio profile. If you are not using ocio, it is safe to ignore it.
fantome
Thanks for the very fast publish juanjo ! I was wondering if this is the version with the new QT IPR enable ?
juanjgon
fantome wrote:Thanks for the very fast publish juanjo ! I was wondering if this is the version with the new QT IPR enable ?
Not yet. Now that the Octane 2020.2 version is almost ready, I'll continue working on it to have it ready ASAP.
fantome
great ! thanks for your fast answer juanjo.
WoutTgh
so what's the workflow to get ACES/OCIO to work in the IPR in Houdini? If anyone could shed some light on that, I'd appreciate that :)
Wout
trogers
Hey WoutTgt,
I figured out a solution to be able to view ACES through the IPR. I posted about it here:
viewtopic.php?f=9&t=76948&p=396410#p396410
Best / Travis
Win 10 / AMD 3970x / Nvidia 4090 + 2080 Ti / 128GB
Return to “Releases”
