OctaneRender 2020.2 LightWave Alpha build 2020.2.0.0
Forums: OctaneRender 2020.2 LightWave Alpha build 2020.2.0.0
Re: OctaneRender 2020.2 LightWave Alpha build 2020.2.0.0
Postby NemesisCGI » Fri Jan 29, 2021 7:43 am
NemesisCGI Fri Jan 29, 2021 7:43 am
promity wrote:I found a problem with Displacement:
https://youtu.be/PEi2Oljnimw
Maybe your mesh has no UV?
Win 7 pro 64bit GTX780
NemesisCGI
Postby promity » Fri Jan 29, 2021 8:06 am
promity Fri Jan 29, 2021 8:06 am
Yes! Thank you - I totally forgot about it )
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
promity
Postby xevious2501 » Thu Feb 11, 2021 3:21 pm
xevious2501 Thu Feb 11, 2021 3:21 pm
Question?.
IS lightwave DCC UV's limited to only 3?
In octanes materials, the toggle only lists for 3 UV options, is there a way to increase or select the named UV from the object?
xevious2501
Postby juanjgon » Thu Feb 11, 2021 9:35 pm
juanjgon Thu Feb 11, 2021 9:35 pm
This is an Octane core limitation. Octane only supports 3 UV maps in each object.
juanjgon
Postby rustyippolito » Thu Feb 11, 2021 9:58 pm
rustyippolito Thu Feb 11, 2021 9:58 pm
+1 on revealing the UV names in the Octane nodes:)
rustyippolito
Postby pixelsmack » Thu Feb 11, 2021 10:02 pm
pixelsmack Thu Feb 11, 2021 10:02 pm
I asked for at least showing the names before. I’ll ask again! :)
pixelsmack
Previous
Return to Releases
Sat Jun 15, 2024 9:17 pm [ UTC ]
