OctaneRender 2020.2 LightWave Alpha build 2020.2.0.0
NemesisCGI
promity wrote:I found a problem with Displacement:
https://youtu.be/PEi2Oljnimw
Maybe your mesh has no UV?
Win 7 pro 64bit GTX780
promity
Yes! Thank you - I totally forgot about it )
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
xevious2501
Question?.
IS lightwave DCC UV's limited to only 3?
In octanes materials, the toggle only lists for 3 UV options, is there a way to increase or select the named UV from the object?
juanjgon
This is an Octane core limitation. Octane only supports 3 UV maps in each object.
rustyippolito
+1 on revealing the UV names in the Octane nodes:)
pixelsmack
I asked for at least showing the names before. I’ll ask again! :)
Return to “Releases”
