SoftImage XSI Plugin v1.022f [Obsolete]
face
Showtime ;)
Have build a new version from the plugin with the native unit size.
AND i have updated the plugin for XSI6/6.5.
In words, render camera only and the native unit size is integrated.
Changing the mesh size will change the aperture and focaldepth units too.
The use is simple, the cube in the image below is oversized, 20 SI-Units.
To export a rescaled version, change the native unit size from meters to decameters, the result should be 2m.
In this image, the cube is undersized, 0.2 SI-Units.
To export that, change the native size to decimeters.
A note, you don´t need to rescale the exapmles above, Octane should render it correct in hers original size.
The function make sense for very small or very large meshes.
This function will work on everything you will export, meshes AND PointClouds.
The 6er version isn´t testet, maybe there are some issues...
Have fun...
face
Octane_6.zip
(410.03 KiB) Downloaded 540 times
Octane_7.zip
(515.6 KiB) Downloaded 536 times
Octane_2010.zip
(515.63 KiB) Downloaded 609 times
http://vimeo.com/user2509578
jamnique
Hehe i just downloaded the previous version :) Great job on the plugin. I will test the s*** out of the new one today.
One question: I remember vaguely reading a thread here on avoiding internet related problems while rendering animations. If i recall correctly, Radiance suggested that the problem could be handled inside the plugin with a kind of batch script. Have you read it? Do you think it could be done?
Intel Core2Quad 9200 / 4 GB OCZ / Gainward 460 2GB
face
Yes, i have read it, but i forget the workaround :oops:
face
madelgado
Great man! Thanks for your work face. ;)
Marco Antonio Delgado
pixeltale studio
Render out!
Spain
jamnique
Is it just me or is the new plugin exporting faster ? :D It works perfectly smooth so far :) The scale feature is a blessing. Really great job Face.
"Export camera only" works for me, but i still can't get motion blur to work. Or maybe it's just to subtle to see.
About the internet-disconnection failsafe, i hope it will make it into Octane or your plugin some day, but even without it it pays off to use Octane on a job.
Once again thanks for making the XSI-Octane workflow a pleasure.
face
jamnique wrote:Is it just me or is the new plugin exporting faster ? :D It works perfectly smooth so far :) The scale feature is a blessing. Really great job Face.
Thanks ;)
MB works only with camera movement. Object MB isn´t supportet by Octane, yet...
For that you can do it in post. I use RealSmartMB and have make a crossgrade from 3.3SI to 4.0OFX for composite that comes with the 2011SAP.
You pay then 114$...
face
jamnique
face wrote: MB works only with camera movement. Object MB isn´t supportet by Octane, yet...
The thing is i can't get camera motion blur, or for some reason it's not strong enough to be noticeable.
face
To test it, type in a JScript windows "SetValue("Octane_exporter.debug", true, null);"
Hit the render button and you will see some information in the script window.
One parameter is the cCam.
It should look like this:
// INFO : cCam: --cam-up-x -0 --cam-up-y 0.995037 --cam-up-z -0.0995037 --cam-target-x 0 --cam-target-y 0 --cam-target-z -3.55271e-015 --cam-pos-x 0 --cam-pos-y 3.09589 --cam-pos-z 30.9589 --cam-motion-up-x -0 --cam-motion-up-y 0.995037 --cam-motion-up-z -0.0995037 --cam-motion-target-x 0 --cam-motion-target-y 0 --cam-motion-target-z -3.55271e-015 --cam-motion-pos-x 0 --cam-motion-pos-y 3.09589 --cam-motion-pos-z 30.9589 --cam-fov 53.638
The motion parameters are the camera pos/up/dir values in the next/prev frame.
You can test it, if you have selected next as interpolation, when you go to the next frame and hit the render button again.
The actual camera values should then have the values from the prev motion values...
In the example above there is no camera animation, because the values are equal...
Hm, have tested it now and i don´t see any MB.
The values are exported correct, maybe a Octane issue, i will post it...
face
jamnique
Thanks! I will test it today. To say the truth it didn't seem to work in the previous version either. I'll give it a try and post results soon after work.
jamnique
face wrote:To test it, type in a JScript windows "SetValue("Octane_exporter.debug", true, null);"
Turns out i don't know where is JScript window :P
But i did some strands tests for the first time and i like what I'm seeing :D Very straightforward. Thanks to you i can render my graduation project entirely in Octane ;]
Return to “Autodesk Softimage XSI”
