OctaneRender™ 2020.2 RC6
abstrax
linograndiotoy wrote:Hi,
It looks like we may have a problem wit objects whose normals have been edited.
Load the scene and rotate the view. You'll notice the shading will not be constant as defined by the normal editing.
This happens in previous versions as well.
I've used the Toon Material so to make the fact more evident.
The vertex normals are coplanar to the polygon surface, i.e. are invalid. In those cases a filter comes into play that tries to fix artifacts caused by smooth normals that diverge too much from the face normal and are viewed from glancing angles. This filter takes the viewing angle into account and makes the "fixed" smooth/shading normals view dependent. In your case the vertex normals are so far off that there is nothing that can be done anyway.
-> It's not a bug but a feature.
SSmolak
I have error when render is stopped and started again. It is related to Cinema 4D plugin and Standalone version too. I have two NVlinked 2080ti
abstrax
SSmolak wrote:I have error when render is stopped and started again. It is related to Cinema 4D plugin and Standalone version too. I have two NVlinked 2080ti
Thanks for the report. Currently looking into it. (See also viewtopic.php?p=395065#p395065)
galleon27
Is it possible to add the Alpha channel to Channel Picker, Merge, etc.?
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
Jolbertoquini
Hi Guys,
I find a bug, everything is working for me with ACES but when I render the output with all passes all the passes is good except the Depth pass is rendering weird when ACES is activated. the exr as linear is not exporting also properly. All other passes looks like is all good color passes
but on the info channel should be ignored by aces I think specially when we export linear :)
ACES ON
ACES ON
ACES OFF
ACES OFF
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
linograndiotoy
As a 3d artist, I have to say I don't like this feature that much, and I would love to be able to turn it off if possible. Defining custom normals may be really important for NPR and game assets, and those should stay consistent from any camera angle.
I made a video showing how other renders (in order LightWave and Cycles, but it really works fine in any other render I tested) can correctly manage this kind of situation:
https://youtu.be/ijWK1dNmKvo
KeeWe
Are there any infos about headless rendering, when to be expected and a rough explanation how it will work with the c4d plugin?
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
karl
Jolbertoquini wrote:Hi Guys,
Thanks for the report. The issue with the weird stripes in the depth pass will be fixed in the next build.
I'm not quite sure about the EXR export problem though - that seems to work fine. What problem are you seeing? If it's that the entire image looks white, that's just because the depths are likely to be greater than 1.0 - they're there, you just can't see them in a normal viewer unless you reduce the exposure.
Jolbertoquini
no export is working sorry my bad I didn't express properly haha is the info passes normal, uv , depth, position they have issues
BCres
aoktar wrote:
useruser wrote:
Mikla wrote:Hey there;
Having render freeze when I have objects with keyed visibility attiributes. Tested with default cinema4d visibility property and octane tag visibility slider.
When the render reaches to the frame with the visibility key it stops calculation and hangs. This doesnt happen in the LiveViewer.
Im using HDR/sRGB output with no denioser. 2x RTX3080. having RTX on or off doesnt make a difference. I'm sending the sample scene file to aoktar.
same problem here: rendering hangs up in pictureviewer.( not in live viewer) with both options:animated visibility property in octane-objecttag or the c4d-standard visibility-tag.
so i switched back to octane 2019 because it was unable to render the project.
It was a problem from sdk, not plugin part
I'm bringing these quotes over from the C4D plugin forum and wondered if this was being looked at. I have just noticed this same problem in a new project I am working with, too.
The issue is...if the visibility attributes are keyed on/off, and you are anywhere in between those keyed frames, Octane freezes. I can work all day long in this same project as long as I avoid that portion of the timeline.
It doesn't happen in 2020.1.5 with the same project, only in the 2020.2 RC6 release candidate. Thank you.
