OctaneX Studio/Enterprise PR7 for BigSur
james_conkle
Works well on my 2019 16in. MBP. Does this version have the new Tone Mapping that's in the current Cuda release candidate?
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
@ jamesbat420: please disable AI Denoiser, there is an issue with Big Sur 11.1.
Please also disable the Intel GPU in Octane Settings/Devices panel, if present, and render only with AMD GPUs for now.
@ james_conkle: nope, OctaneX PR7 is basically identical to v2020.1.5 CUDA.
ciao Beppe
Weezer
bepeg4d wrote:@ jamesbat420: please disable AI Denoiser, there is an issue with Big Sur 11.1.
Er, an issue with Big Sur or an issue with OctaneX? Please don't say we have to wait for yet another macOS update...
james_conkle
I've also noticed that when I enable a render region of any size the samples stop at 60 no matter what my target samples are. In CUDA it'll keep going even past the "Spp" I set in Octane Settings (Which isn't perfect but better than caping at 60).
hi james,
no problem here with both render region, that continues after the max samples assigned:
and film region, that stops at the max samples assigned:
ciao beppe
Weezer
Hi Beppe – any sign of an OctaneX PR8? Or the full v1 release for that matter?
Weirdpictures
Hi Aoktar,
thanks for this incredible test release. I can't believe that i am seeing octane running on our 2013 trashcan Mac Pro. I thought it wouldn't be supported, just newer AMD GPU's, but it actually works great on our old machine. Only caveat is that it seems to not like rendering on both integrated AMD GPU's. If we activate both GPU's the live viewer always shows a checker pattern, like both GPU's have a different output. But if we render with just one GPU activated it works perfectly fine (But yes, of course only half the speed :-)
Anyway, unexpected that it works at all, so can't complain. I will try to install R23 today to see if it makes a difference, as well as check it out on our MacBook pro 16 inch from 2020, very exciting times :-)
Thanks for all the hard work over all these years, we love octane on C4D.
Best,
Martin
cjadams
I have noticed that the GPU selection settings do NOT persist after a reboot..
If i come back the next day.. and try and use octane.. i get a ton of console errors. till i go in and RE DISABLE the intel graphcs.
is there a reason this does not save?
If I uncheck the intel gpu.. as long as i keep cinema open.. or even if I close and re-open Cinema. Or even logout and login again it seems to stick.. but a computer reboot takes it away again and i get the Gpu errors.
Cinema R23.008 Build RB323902
Confirmed at least for me.. it persists even after restarting C4d or even Logging out and logging in again into Macos - But.. it reverts to having the intel one selected...if i Reboot the whole machine. NOTE that i'm on Macos 11.1 with "automatic Graphics switching" Disabled - Macbookpro 2019 16 inch. AMD Radeon Pro 5300m
plasmapeppers
Weirdpictures wrote:Hi Aoktar,
Best,
Martin
If you disable tonemapping on one of them the checker pattern will disappear - you can see the setting for it in cjadams's post right above this one ;)
CUDA
i7-7820X 96GB + 1080Ti
i7-8650U 16GB + 1060M
Metal
Mac mini i7-8700B 32GB + Radeon VII eGPU
Return to “Releases”
