OctaneX Studio/Enterprise PR7 for BigSur
This is a test build for Big Sur with experimental M1 support. Please don't use for production scenes. Enjoy it!
Please update to Big Sur 11.1
Studio
https://render.otoy.com/customerdownloa ... Studio.zip
Enterprise
https://render.otoy.com/customerdownloa ... BigSur.zip
drunknbass
Awesome!
Any idea when this drops for studio subs?
blakfulcodes
PR7 keeps crashing on macOS version 11.1 and PR5 doesn't work either. :?
Did you guys test PR7 works fine on 11.1?
Goldorak
We did QA here and in closed beat - what set up are you running?
Weezer
Is there a way we can test this in demo mode? I don't want to resubscribe only to find it still doesn't work.
Goldorak
Weezer wrote:Is there a way we can test this in demo mode? I don't want to resubscribe only to find it still doesn't work.
Demo and prime versions are in progress.
Weezer
Okay, great, thanks!
plasmapeppers
It also doesn't work for me, says there is a heap allocation error.
Application Specific Information:
/Applications/Maxon Cinema 4D R22/plugins/OctaneX_Enterprise_PR7_BigSur/liboctane.dylib
abort() called
Cinema 4D(7455,0x10d451e00) malloc: Incorrect checksum for freed object 0x7fd9bee4ee40: probably modified after being freed.
Corrupt value: 0xcd0ba4e2ae22dc35
I have a Mac mini 2018 i7, 32GB RAM, Radeon VII eGPU on macOS 11.1 Big Sur.
edit: forgot to mention that this is on starting C4D - it doesn't even get to the splash screen.
CUDA
i7-7820X 96GB + 1080Ti
i7-8650U 16GB + 1060M
Metal
Mac mini i7-8700B 32GB + Radeon VII eGPU
Goldorak
plasmapeppers wrote:It also doesn't work for me, says there is a heap allocation error.
abort() called
Can you test PR7 standalone (posting shortly) to see if the same issue happens outside of C4D?
plasmapeppers
Ok with the PR 7 Standalone it works as expected - and its definitely faster! I suspect the crashing might have something to do with code signing as the PR7 DMG + the App bundle were not signed properly - had to override, and so it might be that the Cinema 4D version isn't giving me the chance to override and is just crashing. Just speculation though.
CUDA
Metal
