Cinema4D version 2020.2-RC6 (Release candicate) 29.12.2020
divasoft wrote:HI. I constantly get crushes denoising process with RC6 release. Cinema just crush without any messages.
Please, try to export to Standalone 2020.2-RC6, and check if the issue with Denoiser is still present.
I have reported a couple of issues with Denoiser to the core devs, and should be fixed for the next version.
ciao Beppe
BiteDXH wrote:Liveview saves different results from the rendering of the picture viewer. I set up the ACEScg color space. It seems that the color space of the picture viewer is still AES 2065-1.
and where is the idt of the srgb texture? can you provide an osl script?
Use other config checkbox should be checked. LV doesn't use any display color management on output colors, for a correct comparison be sure you're using linear
BiteDXH
Yes i checked and result is still different.‘File-save image as’ can save the same results as liveviewer
BiteDXH wrote: Yes i checked and result is still different.‘File-save image as’ can save the same results as liveviewer
Different because Picture viewer has "display color profile". It's out my control, disable it. Also what you see is correct in LV.
BiteDXH
Hello, aoktar. I used octane own ACEScg in the rendering settings and the result is correct. I suspect that there is no read ocio settings in the rendering settings.
BiteDXH
Hi @bite, there shouldn't be a mistake for my side. It's working well if all related parameters set correct. Check intermediate parameters, they are a kind of language interpreter between two different colorspaces(from octane to OCIO)
bloomis2
ACES and OCIO are equally exciting and confusing, as witnessed on this sub! Is there someplace where the workflow is explained properly?
bloomis2 wrote:ACES and OCIO are equally exciting and confusing, as witnessed on this sub! Is there someplace where the workflow is explained properly?
Please check standalone topics, we haven't prepared c4d manual for that
BiteDXH
aoktar wrote:Hi @bite, there shouldn't be a mistake for my side. It's working well if all related parameters set correct. Check intermediate parameters, they are a kind of language interpreter between two different colorspaces(from octane to OCIO)
Intermediate color space should be linear sRGB.Render setting OCIO color space really not work
Return to “Releases”
