Cinema4D version 2020.2-RC6 (Release candicate) 29.12.2020
Hi all,
This is a Release Candicate. This build based on 2020.2-RC6 SDK. Anyway Please DO NOT USE for PRODUCTION purpose. Your some octane settings may get lost with future builds. It's on your risk until remarked as stable. Any feedback will be much appreciated.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows or 455.23 on Linux to use this version. No driver updates are required for macOS 10.13 (CUDA).
This version supports the new NVIDIA Ampere architecture on Windows and Linux. Kepler cards with compute model lower than 3.5 are just supported on macOS.
This is the matching Standalone: OctaneRender™ 2020.2-RC6.
Changes of 2020.2-RC6
- Minor improvements on node editor workflow
- Some fixes for new 2020.2 features
- New normalized info passes for AOV inputs
- Fix: for sRGB colorspace, fixed the sRGB embedding to saved render pass files
Note that: Tonemapping system changed, old parameters need to be adjusted to obtain the same look.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
WINDOWS ENTERPRISE BUILD (R15-23)
https://render.otoy.com/customerdownloa ... C6_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-23)
OSX ENTERPRISE BUILD (R15-23)
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD (R15-23)
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 450) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
Antoncromas
Hello,
There seems to be a bug with spotlights. The cone is rendering as black. Also if you make the light invisible there is an artifact in the areas where the cone of the spot light passes through. Please see attached images and cinema 4D files.
SpotLight Bug.rar
(143.03 KiB) Downloaded 493 times
eyeonestudio
Thanks RC6. I will try today. :)
eyeonestudio
Antoncromas wrote:Hello,
Texture Environment > Type > Primary Environment
eyeonestudio
Network Rendering Test - Very Stable Here. :D
All RTX3090 * 9(M3, S2+2+2) / RTX:On
Live Viewer / Network Rendering:3 Slave - Distribute Speed: Good, Keep Connection: O.K
Picture Viewer / Network Rendering:3 Slave / 100frame Sequence - O.K
divasoft
HI. I constantly get crushes denoising process with RC6 release. Cinema just crush without any messages.
SSmolak
Does final version will include new scattering tools from Standalone ?
SSmolak wrote:Does final version will include new scattering tools from Standalone ?
I don't make any plans for that. Plugin have own scatter object.
Kalua
Solid build so far!
New node's features are sweet! Really nice.
Best regards,
FL.
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
BiteDXH
Liveview saves different results from the rendering of the picture viewer. I set up the ACEScg color space. It seems that the color space of the picture viewer is still AES 2065-1.
and where is the idt of the srgb texture? can you provide an osl script?
