I couldnt find any information on this, any idea how we can achieve this ripple animation effect with Octane? I could able to do ripple look on a still image but I am trying to do the animation like this when the drops fall down on a surface.
https://www.youtube.com/watch?v=azdEAlT7NR0
Ripple Effect with Octane
You would most likely want to do this effect with c4d features and then merely apply octane materials and lights.pinarer wrote:I couldnt find any information on this, any idea how we can achieve this ripple animation effect with Octane? I could able to do ripple look on a still image but I am trying to do the animation like this when the drops fall down on a surface.
Don't look for octane tutorials on this. Follow c4d tutorials. Octane for the rendering of final look.
- jayroth2020
Did you try using the baking node in your material network? Add it after the ripple effect and see if that helps.
Thanks @jayroth2020 for the reply , i just tried it, it didint work , but not sure if I am doing right, I converted the material and then add the bake texture, I attached 2 images, one of them after i converted to octane material , the other one after i add bake texture node. Is this look right?
@lanklaf yes i did that for a still image but I am trying to do for an animation, and not just one ripple in the middle, I used emitter like that in that video, drops are falling down and each time they fall down I would like to have the ripples in an animation
