film width / film index
k0ttyy
Hello,
I'm a beginner with Octane and I'm a little lost.
When I want to create a pearlescent material but I can not find "film width" and "film index".
Here is what looks like:
thank you in advance for your help.
you have selected the Sheen tab, that is a completely different characteristic than Film Layer, please have a look at the manual here:
http://www.aoktar.com/octane/OCTANE%20H ... lated.html
If you double click on material, and use the separated Material Editor window, it is not complete.
Please, edit your materials in Attribute Editor, or in Node Editor:
ciao Beppe
soundboutique
I also do not see film index and film width in my materials... I only see Film LAYER. How do we get the other two to show up in the options?
Perhaps in this newer version of octane film layer is those two settings combined?
Under materials the only option that shows any additional film settings are under the universal material type, but that is only thin film layer.
Although, in the attributes section i see 'Sheen layer', 'coating layer', and 'thin film layer'. Wondering if those are similar settings but the new options for index and width.
Thank you in advance!!!!
reptiliano
Hi, do you found the solution? I have the same problem
Which problem exactly?
Which version have you installed exactly?
Please always share some screenshots, thanks.
ciao Beppe
ATjag
He's saying film index and film width are not present in the material/node editors.
I'm actually here because I'm having the exact same issue. See the screenshot below.
Sorry but I don’t get why you think it is wrong :roll:
Those on the left are the names of the channels of the material, not the list of all the available parameters.
Each channel could have several parameters.
Just select the Film Layer to see the specific parameters of that channel.
ciao Beppe
mlhlw
hey guys,
open the material in the node editor.
there you have the film index and width.
or in the film layer tab:
float = film width
film IOR = film index
Return to “OctaneVR Questions & Discussion”
