Cinema4D version 2020.2-RC5 (Release candicate) 23.12.2020
VVG
Mikla wrote:Thanks for the release.
Plugin crashes on render to picture view. Live Viewer works fine.
C4D R17, empty scene. Including logs.
Best.
R23 Same
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
Best.
R23 Same
Obvious bug here, checking it
Mikla
Best.
R23 Same
jianle wrote:can not render to picture viewer,mds!!!!
It's a bug case! Removed download links and replacing with fixed builds. Please redownload when you see links are up again! Sorry for trouble, results of doing it urgent
remix wrote:Hey there! I don't know how much of the Aces implementation is under development vs not looked into so here are a few things:
- The "View" dropdown menu doesn't do anything
- Missing option to load in OCIO profiles
- Missing AcesCG
- Missing the option to select the target gamut output (also known as View Transform)
I hope all of these mandatory Aces features make it to the final release!
Can you clarify what you mean exactly? Where are you looking to?
Mikla
Render to Picture Viewer works now thanks Ahmet.
Denoiser works too. Please note that the status bar on the pıcture viewer is gone.
Mikla wrote:Render to Picture Viewer works now thanks Ahmet.
Hi! I don't see any problem with that, can you show me it?
Mikla
Some scenes are throwing this error:
denoiserThread0: CUDNN_STATUS_BAD_PARAM
. Restart required
not all the passes requested for tonemapping are enabled
Hangs the PC as well.
Edit: Scene renders normally in LV
Mikla
Weirdly the black screen issue happened on an empty scene with a cube as well.
Tried to access pin via an invalid ID P_DEEP_ENABLE (263)
Tried to access null node pin
Can't read bool from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFA1F2492E0)
Please change BUFFERTYPE to HDR, not to HDR-HALF, it's default and will fix it.
Return to “Releases”
