R23 SameMikla wrote:Thanks for the release.
Plugin crashes on render to picture view. Live Viewer works fine.
C4D R17, empty scene. Including logs.
Best.
Cinema4D version 2020.2-RC5 (Release candicate) 23.12.2020
- gif.jpg (12.87 KiB) Viewed 3916 times
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
Obvious bug here, checking itVVG wrote:R23 SameMikla wrote:Thanks for the release.
Best.
It's a bug case! Removed download links and replacing with fixed builds. Please redownload when you see links are up again! Sorry for trouble, results of doing it urgentjianle wrote:can not render to picture viewer,mds!!!!
Can you clarify what you mean exactly? Where are you looking to?remix wrote:Hey there! I don't know how much of the Aces implementation is under development vs not looked into so here are a few things:
- The "View" dropdown menu doesn't do anything
- Missing option to load in OCIO profiles
- Missing AcesCG
- Missing the option to select the target gamut output (also known as View Transform)
I hope all of these mandatory Aces features make it to the final release!
Hi! I don't see any problem with that, can you show me it?Mikla wrote:Render to Picture Viewer works now thanks Ahmet.
Denoiser works too. Please note that the status bar on the pıcture viewer is gone.
Some scenes are throwing this error:
Hangs the PC as well.
Edit: Scene renders normally in LV
denoiserThread0: CUDNN_STATUS_BAD_PARAM
. Restart required
not all the passes requested for tonemapping are enabledEdit: Scene renders normally in LV
Weirdly the black screen issue happened on an empty scene with a cube as well.aoktar wrote:Hi! I don't see any problem with that, can you show me it?Mikla wrote:Render to Picture Viewer works now thanks Ahmet.
Tried to access pin via an invalid ID P_DEEP_ENABLE (263)
Tried to access null node pin
Can't read bool from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFA1F2492E0)
Please change BUFFERTYPE to HDR, not to HDR-HALF, it's default and will fix it.
- a1.jpg (14.26 KiB) Viewed 3885 times
